> Yellow or Green Driving Light Switch ?, 74 914 2L
thompson-mfr
post Dec 17 2013, 06:14 PM
Thompson, Ryan
What color is the driving light switch supposed to be for 1974? I have a green one in the car, but in a parts bin I noticed a yellow one.
toolguy
post Dec 17 2013, 06:57 PM
IIRC, Yellow is for fogs lights. . the button has the symbol for the light beams being focused downward. on TN1 and TN2 lights 1970 - 72 . Green buttons had the symbol for the light beams going straight out, for driving lights. .TN4 1970 -74
75 and 76 only had fogs. .
Hella TN1-TN2 Fog Lamps: 1970 - 1972
The Hella TN1-TN2 fog light was available on the 1970-1972 Porsche 914 model years and the Porsche 914/6 models. They are round Hella lamps comprised of a semi-gloss black housing attached to the mount base with four unpainted brass rivets, a gloss-black painted brass trim ring, a reflector dish, a light diffuser, a 35 or 45 watt Phillips bulb, a 110mm Hella TN1-TN2 lens, a lens gasket, four wire lens clips, a wire grommet and a ring retainer clip (with screw). The lens has a horizontal offset about one-third the way up the vertical fluting. The trim ring is molded to angle the ring face inward. The light diffuser that shields the bulb in the TN1-TN2 lamps is chrome.
Hella TN4 Driving Lamps: 1970 - 1974
The more prevalent optional 1970-1974 Porsche 914 driving lights are also round, 110 mm diameter Hella lamps with the same components as the TN1-TN2 models, but the lenses are the Hella TN4 units which have no horizontal offset. The painted brass trim rings on many of the TN4 lights have flat, unmolded faces. The light diffuser that shields the bulb in the TN4 lamps is unchromed tin. Normal problems associated with both styles of the round Porsche 914 and 914/6 driving lights are lens wear & cracking from road debris, ring paint wear and chipping from same, housing rust and reflector dish rust.
thompson-mfr   Yellow or Green Driving Light Switch ?   Dec 17 2013, 06:14 PM
boxsterfan   On my 1974 2.0L it is yellow. Top picture is a 914...   Dec 17 2013, 06:24 PM
thompson-mfr   On my 1974 2.0L it is yellow. Top picture is a 91...   Dec 17 2013, 06:27 PM
eric9144   Should be yellow, green is earlier than 74...   Dec 17 2013, 06:25 PM
toolguy   IIRC, Yellow is for fogs lights. . the button has...   Dec 17 2013, 06:57 PM
Pursang   The button cover on that switch is yellow in my 19...   Dec 17 2013, 07:42 PM
SirAndy   driving light switch Not to be picking nits here, ...   Dec 17 2013, 07:43 PM
thompson-mfr   driving light switch Not to be picking nits here,...   Dec 18 2013, 12:36 AM
johannes   What is the difference between fog and driving li...   Dec 18 2013, 06:06 AM
SirAndy   What is the difference between fog and driving lig...   Dec 18 2013, 12:46 PM
Highland   My light switch is black with a door jam sticker d...   Dec 18 2013, 09:30 AM
eric9144   driving light switch Not to be picking nits here,...   Dec 18 2013, 10:34 AM
SirAndy   Not true--true in the US, but not european deliver...   Dec 18 2013, 12:43 PM
sarivers2001   Not true--true in the US, but not european delive...   Aug 21 2023, 02:21 PM
SirAndy   Question, re: this old thread. Is it correct to ...   Aug 23 2023, 07:48 PM
Hawk   That is one beautifully done car! Love the hoo...   Dec 18 2013, 12:12 PM
OU8AVW   So on my 1971 4 I should have a green switch for m...   Dec 18 2013, 12:53 PM
SirAndy   I am also adding a set of additional driving light...   Dec 18 2013, 01:00 PM
eric9144   True to every stock 914. Fog lights, never ever ...   Dec 18 2013, 06:04 PM
Stephen Paul   Responding to the questions about green and amber ...   Oct 19 2021, 04:17 AM
Shivers   @Stephen Paul That is quite a first post. :) :...   Oct 19 2021, 05:04 AM
rgalla9146   ....Goodness gracious   Oct 19 2021, 05:24 AM
StarBear   ....Goodness gracious :agree: My original 74 1...   Aug 21 2023, 05:56 PM
Cal   This is great info. I’m is the middle of instal...   Oct 19 2021, 06:05 AM
Ansbacher   I have a '74 2.0 therefore my car came with a ...   Oct 19 2021, 11:12 AM
douglastic   I love how "green or yellow?" results in...   Oct 19 2021, 11:34 AM
Puebloswatcop   To make it simple, Yours is a '74. Headlight ...   Oct 19 2021, 07:12 PM
Cairo94507   @Ansbacher - For additional visibility, get a set...   Oct 20 2021, 06:46 AM
Big Len   More than I ever wanted to know about specific fog...   Oct 20 2021, 02:01 PM
eric9144   My 74 014 2.0L has the lights inside the bumper, ...   Aug 21 2023, 03:13 PM
sarivers2001   My 74 014 2.0L has the lights inside the bumper,...   Aug 23 2023, 12:42 PM
Front yard mechanic   Ai bot   Aug 21 2023, 06:48 PM
eric9144   @sarivers2001 those are US spec fogs with the cor...   Aug 23 2023, 01:17 PM
sarivers2001   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Aug 23 2023, 07:38 PM
- Lo-Fi Version Time is now: 11th March 2026 - 07:55 AM
