> Daily Driver just wants to know, calling all DDs!
malcolm2
post Dec 18 2013, 07:56 AM
I have not driven an aircooled VW as a DD for 30 years, and that was a 68 bug. As most probably know, those cars had a speedo and a gas gauge. Very little feed back.
I am curious about how the 914 should run. I have a freshly built and fuel injected 1911 engine, with larger valves on 1.8 style heads. I am running a 75 exhaust. I am getting lots of feedback from the car and I think it drives great! (IMG:style_emoticons/default/piratenanner.gif)
This car seems to have lots of power, compared to the 68 bug. (IMG:style_emoticons/default/beerchug.gif) I run to about 3500 rpm then shift to 2nd. Thru the gears at about the same rpm, and usually wait to shift to 5th 'til about 50 mph and it cruises between 2800 (55-ish mph) and 3200 (70-ish mph) in 5th. That seems strange, cause they put the blinker indicator right at 3000! It gets blocked all the time (IMG:style_emoticons/default/idea.gif)
I still have lots of power left at 70. If I give it some pedal at 70, it will hop right up to 80, no problems. My ODO is broken, so MPG is unknown, but my goal is to maximize that.
CHT seems to like the 3200 cruising. I notice about a 50 deg drop after a few miles on the interstate, which makes sense. The VDO CHT gauge with the spark plug sensor on #3 runs between 325 and 350 normally.
I am being clear, can everyone follow? How does that sound, as far as DD operation?
Clark
(IMG:style_emoticons/default/driving-girl.gif)
'73-914kid
post Dec 18 2013, 06:28 PM
I agree with using 4th on the freeway if you're close to 60mph, but shifting at 4k-4.5k RPM? I've never heard that on any engine except a rotary. type IV's redline at what, 5700 RPM? So you're using 75% of your RPM band just shifting around town? No thanks.
I would shift at around 3000 RPM when I had my type 4. And no, that's not lugging the motor.
Sounds like a way to wear out an engine quicker than normal. More time at a higher RPM is going to wear rings, valve guides, valve seats, and bearings faster. Maybe I'm overly conservative because I drive my car every day, and don't want to spend a bunch of money on the above parts because I spun the thing close to redline every time I shifted gears.
Drive it how you want though. People always say I drive like a wimp because I don't spin my motors on a regular basis. And no, I don't, because I need them to last and can't afford rebuilds. If it was a weekend driver, I'd drive it like I stole it, because if something broke, I could hop in my other car, and there would be no problems.
My 2 cents about shift points in a daily driven car....
malcolm2   Daily Driver just wants to know   Dec 18 2013, 07:56 AM
jimkelly   what - you drive your 914 - hum - that is a great ...   Dec 18 2013, 08:02 AM
wndsnd   Check the 914 information tab at the top of the Fo...   Dec 18 2013, 09:32 AM
malcolm2   Fuzzy picture in my work parking lot, from my ...   Dec 18 2013, 10:22 AM
rdauenhauer   The 1911 is a nice engine. Its definitely nice to...   Dec 18 2013, 11:03 AM
boxsterfan   Mine pretty much drives as exactly as you describe...   Dec 18 2013, 11:21 AM
'73-914kid   Been driving my car every day rain or shine for th...   Dec 18 2013, 11:24 AM
malcolm2   Been driving my car every day rain or shine for t...   Dec 18 2013, 06:22 PM
malcolm2   Everything else sounds good to me, get an oil tem...   Dec 18 2013, 06:37 PM
Cap'n Krusty   3500 RPM is cruising speed, NOT where you should b...   Dec 18 2013, 11:32 AM
malcolm2   3500 RPM is cruising speed, NOT where you should ...   Dec 18 2013, 06:17 PM
ChrisNPDrider   What size tires are you using? I have 205/50s now...   Dec 18 2013, 11:46 AM
McMark   :agree: Yup, sounds pretty good! I have low p...   Dec 18 2013, 12:36 PM
dlee6204   3500 RPM is cruising speed, NOT where you should ...   Dec 18 2013, 06:11 PM
'73-914kid   I agree with using 4th on the freeway if you'r...   Dec 18 2013, 06:28 PM
McMark   Sounds like a way to wear out an engine quicker th...   Dec 18 2013, 08:56 PM
bandjoey   1800 miles a month for the past year. 2.0 '73....   Dec 18 2013, 06:30 PM
Porsche930dude   odometer is a pretty easy fix. theres a write up o...   Dec 18 2013, 07:01 PM
eyesright   I alternate between my '76 2.0L FI 914 and my ...   Dec 19 2013, 10:10 AM
toon1   You are right in there. I drive mine daily and tha...   Dec 19 2013, 02:50 PM
ripper911   I don't know about a stock engine, but... I d...   Dec 19 2013, 05:47 PM
- Lo-Fi Version Time is now: 27th November 2026 - 07:05 AM
