| DamonsCarrera |
Nov 24 2013, 06:26 PM
Newbie ![]() Group: Members Posts: 36 Joined: 2-September 12 From: Chicago IL Member No.: 14,886 Region Association: Upper MidWest |
The brake pedal on my 914-6 is very spongy, even after repeated bleeding with a pressure bleeder. I isolated the problem to the brake-proportioning valve or pressure regulator. I cannot seem to get the brakes properly bled with this valve in the system.
I've read other posts by some here and it seems this valve is a source of some debate . Is there some trick to bleeding the brakes with it? Do I need to bleed the brakes the old-fashioned way, have someone push on the brake pedal? |
| DamonsCarrera |
Dec 21 2013, 03:51 PM
Sorry for the late response. Work has been a bear lately.
I bled the brakes with the whole rear of the car (regulator and rear calipers) out of the brake system by replacing the line from the master cylinder to the inlet of the pressure regulator with a bleeder valve at the 90 degree connector where it comes out of the back of the firewall. When I do this I get a perfect solid pedal. I also bled the system with only the rear brakes disconnected by replacing the hard line to the rear caliper on each suspension control arm with a bleeder valve. In this case I get a spongy pedal. On initial application of the pedal it feels soft, and if I keep applying pressure to the pedal it goes all the way to the floor, over the course of about 15 seconds. I've tried various approaches to try and get the air out, tapping on the regulator, using speed bleeders and aggressively pushing the brake pedal, going around the car 4 or 5 times. Nothing seems to work. So I guess I have to take out the regulator. I don't have a lift at home. It doesn't look terribly easy to get access to it. I guess I have to take out the heater controls and oil lines. Has anyone else had this experience? |
DamonsCarrera Rear brake pressure regulator valve Nov 24 2013, 06:26 PM
toolguy No trick concerning the proportioning valve. . . a... Nov 24 2013, 06:40 PM
DamonsCarrera Thanks for your input toolguy. I guess I will try... Nov 24 2013, 07:17 PM
nine9three Everybody needs these: http://speedbleeder.com/ Nov 24 2013, 08:44 PM
toolguy Air seeping past the bleeder threads on the calipe... Nov 24 2013, 08:46 PM
914_teener :agree:
+1 Nov 24 2013, 08:47 PM
gothspeed
:agree:
+1
+2 .... :agree: Nov 24 2013, 09:37 PM
Mark Henry If you don't mind the super-fund clean-up mess... Nov 24 2013, 08:56 PM
barefoot
If you don't mind the super-fund clean-up mes... Jan 25 2014, 12:01 PM
ConeDodger Don't remove the valve. You will eventually co... Nov 24 2013, 09:05 PM
walterolin Speed bleeders (above). I did my '70 4 cyl la... Nov 24 2013, 09:29 PM
r_towle After you think you are done, drive it and slam th... Nov 24 2013, 09:47 PM
DamonsCarrera Thanks for all the advice guys.
Mark, besides b... Nov 25 2013, 05:56 AM
Eric_Shea There is no aftermarket valve.
It is a "pres... Nov 25 2013, 05:24 PM
DamonsCarrera I think there are other aftermarket valves availab... Nov 25 2013, 07:47 PM
Racer Chris There is nothing about the pressure regulator whic... Nov 25 2013, 11:32 PM
Racer Chris
There is nothing about the pressure regulator whi... Dec 22 2013, 10:31 PM
Eric_Shea
There's 100's of bias proportioning valv... Nov 27 2013, 04:24 PM
GeorgeRud I wonder if an additional bleeder at the highest p... Dec 21 2013, 05:41 PM
DamonsCarrera The highest point would probably be the at the top... Dec 21 2013, 08:51 PM
DamonsCarrera I've decided for now to replace the factory pr... Dec 22 2013, 01:13 PM
r_towle
The brake pedal on my 914-6 is very spongy, even ... Dec 22 2013, 04:24 PM
Eric_Shea Wrong move. All the Tilton can do is reduce fluid ... Dec 22 2013, 11:48 PM
SirAndy Wrong move. All the Tilton can do is reduce fluid ... Dec 23 2013, 03:15 AM
Racer Chris
Wrong move. All the Tilton can do is reduce fluid... Dec 23 2013, 08:30 AM
Jeff Hail
[quote name='Eric_Shea' post='1973906' date='Dec ... Dec 23 2013, 03:29 PM
Eric_Shea I disagree. ;) Dec 23 2013, 02:22 PM
Eric_Shea You boys have fun... I agree on the pressure aspec... Dec 23 2013, 04:27 PM
DamonsCarrera Don't know what the argument is about. It see... Dec 25 2013, 03:25 PM
DamonsCarrera Well, in case anybody is following this thread ...... Jan 24 2014, 09:39 PM
Bob L.
So next on the agenda, after making a permanent ... Jan 25 2014, 04:29 PM
914_teener I would think your next move is..... if you want t... Jan 24 2014, 10:23 PM
DamonsCarrera Yes, true. I set the valve according to the chart... Jan 25 2014, 10:10 AM
stugray Which model tilton did you get? Did it fit easily ... Jan 25 2014, 11:20 AM
DamonsCarrera @barefoot
I think Mark was referring to cracki... Jan 25 2014, 12:23 PM
914_teener I have re-read your posts and I have a few questio... Jan 25 2014, 02:54 PM
DamonsCarrera @ 914 teener
The difference between a static valv... Jan 25 2014, 05:40 PM
914_teener Ok....so if it is static then the output will be l... Jan 25 2014, 06:05 PM
I'm not sure how you mean to use... Jan 25 2014, 08:03 PM
flypfi DamonsCarrera - I realize this is an old post, but... Nov 21 2016, 04:12 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:17 PM |
