> Rocker set question?
NCRider
post Dec 21 2013, 05:17 PM
Hi all I'm building my 2270 Raby kit. I might be over thinking this but looking at the way the swivel foot seats on the valve stem is off center. Im thinking this is so that the valve rotates and I should not try and line it up on the valve center line. I can do that if it is necessary. How much offset is to much? I ask because some valves are visually different as far as the off set goes. Also how much clearance should I have between the rocker stack and the end block?
JeffAttached Image
stugray
post Dec 22 2013, 10:43 AM
The offset is ok.
When you are done I would be very interested in what you measure for Cam lift and Valve lift. Both intake & exhaust.
- Lo-Fi Version Time is now: 2nd April 2026 - 03:09 PM
