> Rear brake pressure regulator valve, Brake repair
DamonsCarrera
post Nov 24 2013, 06:26 PM
The brake pedal on my 914-6 is very spongy, even after repeated bleeding with a pressure bleeder. I isolated the problem to the brake-proportioning valve or pressure regulator. I cannot seem to get the brakes properly bled with this valve in the system.
I've read other posts by some here and it seems this valve is a source of some debate . Is there some trick to bleeding the brakes with it? Do I need to bleed the brakes the old-fashioned way, have someone push on the brake pedal?
DamonsCarrera
post Dec 22 2013, 01:13 PM
I've decided for now to replace the factory pressure regulator with one made by Tilton. Suitable adjustment will give me the same characteristic (see attachment) as the Bosch unit (which can be seen in a previous attachment). Additionally I can adjust the Tilton valve all the way open when I want to bleed the brakes (this would be possible with every adjustable prop valve out there).
I'm choosing the Tilton valve because they provide alot of technical data which lets me choose a characteristic similar to the Bosch valve, at least to start with, and it's available with metric brake line sizes so I don't have to use adapters.
Attached File  Tilton_98_1261_Brake_Proportioning_Valve.pdf ( 410.95k ) Number of downloads: 678
DamonsCarrera   Rear brake pressure regulator valve   Nov 24 2013, 06:26 PM
toolguy   No trick concerning the proportioning valve. . . a...   Nov 24 2013, 06:40 PM
DamonsCarrera   Thanks for your input toolguy. I guess I will try...   Nov 24 2013, 07:17 PM
nine9three   Everybody needs these: http://speedbleeder.com/   Nov 24 2013, 08:44 PM
toolguy   Air seeping past the bleeder threads on the calipe...   Nov 24 2013, 08:46 PM
914_teener   :agree: +1   Nov 24 2013, 08:47 PM
gothspeed   :agree: +1 +2 .... :agree:   Nov 24 2013, 09:37 PM
Mark Henry   If you don't mind the super-fund clean-up mess...   Nov 24 2013, 08:56 PM
barefoot   If you don't mind the super-fund clean-up mes...   Jan 25 2014, 12:01 PM
ConeDodger   Don't remove the valve. You will eventually co...   Nov 24 2013, 09:05 PM
walterolin   Speed bleeders (above). I did my '70 4 cyl la...   Nov 24 2013, 09:29 PM
r_towle   After you think you are done, drive it and slam th...   Nov 24 2013, 09:47 PM
DamonsCarrera   Thanks for all the advice guys. Mark, besides b...   Nov 25 2013, 05:56 AM
Eric_Shea   There is no aftermarket valve. It is a "pres...   Nov 25 2013, 05:24 PM
DamonsCarrera   I think there are other aftermarket valves availab...   Nov 25 2013, 07:47 PM
Racer Chris   There is nothing about the pressure regulator whic...   Nov 25 2013, 11:32 PM
Racer Chris   There is nothing about the pressure regulator whi...   Dec 22 2013, 10:31 PM
Eric_Shea   There's 100's of bias proportioning valv...   Nov 27 2013, 04:24 PM
DamonsCarrera   Sorry for the late response. Work has been a bear...   Dec 21 2013, 03:51 PM
GeorgeRud   I wonder if an additional bleeder at the highest p...   Dec 21 2013, 05:41 PM
DamonsCarrera   The highest point would probably be the at the top...   Dec 21 2013, 08:51 PM
DamonsCarrera   I've decided for now to replace the factory pr...   Dec 22 2013, 01:13 PM
r_towle   The brake pedal on my 914-6 is very spongy, even ...   Dec 22 2013, 04:24 PM
Eric_Shea   Wrong move. All the Tilton can do is reduce fluid ...   Dec 22 2013, 11:48 PM
SirAndy   Wrong move. All the Tilton can do is reduce fluid ...   Dec 23 2013, 03:15 AM
Racer Chris   Wrong move. All the Tilton can do is reduce fluid...   Dec 23 2013, 08:30 AM
Jeff Hail   [quote name='Eric_Shea' post='1973906' date='Dec ...   Dec 23 2013, 03:29 PM
Eric_Shea   I disagree. ;)   Dec 23 2013, 02:22 PM
Eric_Shea   You boys have fun... I agree on the pressure aspec...   Dec 23 2013, 04:27 PM
DamonsCarrera   Don't know what the argument is about. It see...   Dec 25 2013, 03:25 PM
DamonsCarrera   Well, in case anybody is following this thread ......   Jan 24 2014, 09:39 PM
Bob L.   So next on the agenda, after making a permanent ...   Jan 25 2014, 04:29 PM
914_teener   I would think your next move is..... if you want t...   Jan 24 2014, 10:23 PM
DamonsCarrera   Yes, true. I set the valve according to the chart...   Jan 25 2014, 10:10 AM
stugray   Which model tilton did you get? Did it fit easily ...   Jan 25 2014, 11:20 AM
DamonsCarrera   @barefoot I think Mark was referring to cracki...   Jan 25 2014, 12:23 PM
914_teener   I have re-read your posts and I have a few questio...   Jan 25 2014, 02:54 PM
DamonsCarrera   @ 914 teener The difference between a static valv...   Jan 25 2014, 05:40 PM
914_teener   Ok....so if it is static then the output will be l...   Jan 25 2014, 06:05 PM
DamonsCarrera   @ 914 teener I'm not sure how you mean to use...   Jan 25 2014, 08:03 PM
flypfi   DamonsCarrera - I realize this is an old post, but...   Nov 21 2016, 04:12 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 03:01 PM
