> Rear wheel bearings--play or not, how good is good
barefoot
post Dec 23 2013, 09:43 AM
Just finished refresh of first side of rear suspension, still waiting for correct caliper rebuild kit to replace dust boots.
Question is how much free play is tolerable for the rear wheel bearing. With axles and caliper removed i get about 3/16 possible movement at the tire OD when i rock the wheel side to side (in at the back, out at the front). bearing spins freely with no noise. While I'm in there, i could go for new bearings.
Haven't done the other side yet, so no comparison.
What do the experts say ???
post Dec 23 2013, 10:00 AM
Interesting question, free bump.
rgalla9146
post Dec 23 2013, 10:25 AM
QUOTE(396 @ Dec 23 2013, 11:00 AM) *
No use feeling for play with stub axles removed.
Put the stub back in, then check.
And dont' roll the car or put weight on it without the stubs installed and tight.
barefoot
post Dec 23 2013, 10:50 AM
QUOTE(rgalla9146 @ Dec 23 2013, 11:25 AM) *
Further explanation please, guess i don't understand what rigidity the stub axles add to this equation. They provide no further bearing positioning and I'd think the CV joints add very little to rigidity of the system, but I'm a newbe here, so fill me in.
ThePaintedMan
post Dec 23 2013, 10:57 AM
The presence of the stub axles and the pressure exerted by the axle nut sandwiches the bearing tight, providing the appropriate force on the races and the balls inside of them. Without the whole thing being torqued down, the balls do not fit tightly against the race. This is why people are told NOT to roll the car around or drive it without them being torqued down. It can very, very quickly ruin the balls and/or races, leading to premature failure.
It makes more sense when you have a bearing in your hand, or if you remove the rotor and bearing retainer. You can usually pull the outer half of the inner race off with just a fingernail, exposing the balls. You'll see that there is nothing really holding the race on but the suction from the grease.
- Lo-Fi Version Time is now: 16th July 2025 - 04:22 PM
