> Rear wheel bearings--play or not, how good is good
barefoot
post Dec 23 2013, 09:43 AM
Just finished refresh of first side of rear suspension, still waiting for correct caliper rebuild kit to replace dust boots.
Question is how much free play is tolerable for the rear wheel bearing. With axles and caliper removed i get about 3/16 possible movement at the tire OD when i rock the wheel side to side (in at the back, out at the front). bearing spins freely with no noise. While I'm in there, i could go for new bearings.
Haven't done the other side yet, so no comparison.
What do the experts say ???
ThePaintedMan
post Dec 23 2013, 10:27 AM
You can't get a good estimate of bearing movement without the stubs installed and the axle nut torqued to spec.
That being said, now would be a very good time to do them. Not that expensive, and it'll save you from having to align it twice IF you end up having to pull it all apart again later if the wheel bearings end up going bad. Very likely that they're the original bearings if you don't have documentation that they've been done already.
Cap'n Krusty
post Dec 23 2013, 11:02 AM
Cap'n Krusty
QUOTE(ThePaintedMan @ Dec 23 2013, 08:27 AM) *
Most folks do the job with the arms in the car. No need for an alignment.
The Cap'n
ThePaintedMan
post Dec 23 2013, 11:13 AM
QUOTE(Cap'n Krusty @ Dec 23 2013, 12:02 PM) *
The Cap'n
That's true. That's how I'm doing mine with a threaded rod. Is that how you do it Cap'n? I like having the leverage with the arm on the car. Of course, other folks prefer a press and in that case, the arm comes off and it needs to be realigned.
rgalla9146
post Dec 23 2013, 12:49 PM
[quote name='ThePaintedMan' date='Dec 23 2013, 12:13 PM' post='1974045']
[quote name='Cap'n Krusty' post='1974043' date='Dec 23 2013, 12:02 PM']
The Cap'n
[/quote]
[/quote
regarding the original question.
If you want to evaluate rear wheel bearing condition remove the half shaft and CVs' from the stub axle. re-install the stub axle alone and re-torque. remove the brake pads. install a wheel/tire.
At that point you can feel for play or better yet, spin and listen.
- Lo-Fi Version Time is now: 16th July 2025 - 05:00 PM
