tumamilhem |
LUFTBRIGADE ![]() ![]() ![]() Group: Members Posts: 1,228 Joined: 29-October 12 From: Jacksonville, FL Member No.: 15,092 Region Association: South East States ![]() |
Apparently the computer in my 1974 2.0 is not working properly and making the car run rich. Does anybody know where I can find another one or who to go to have mine rebuilt? It's for a 1974 2.0 with D-jet fuel injection.
Also my 3rd cylinder is misfiring. Would this have anything to do with the computer? If not, any idea what may be causing it to misfire? I have a new working AAR valve installed, my MPS works, no bad wiring in the wire harness or spark plug wires, the timing and dwell are on point and the valves are adjusted. (IMG:style_emoticons/default/confused24.gif) |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
I have two bosch Djet test machines if you think that would work.
rich Attached image(s) ![]() |
tumamilhem |
I have two bosch Djet test machines if you think that would work. rich Wow that's sweet! It seems I have ongoing issues with my fuel injection. Or it's the same issue and just hasn't been found yet. All I know is that I've taken my car back for the same thing three times now. It's been in the shop for three months and six months total in nine months. I replaced the AAR valve, the MPS is good and has a new CHTS sensor. I don't want to keep replacing parts that may not need to be replaced just to take it back again for the same thing. Series 9 is about 2 hours from me. But my car isn't running still to drive it. Thank you guys for all the input suggestions. I will forward them to my mechanic. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,257 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Thank you guys for all the input suggestions. I will forward them to my mechanic. What state is your engine harness in? (IMG:style_emoticons/default/idea.gif) I had a whole slew of FI problems on my 1.7L D-Jet and one weekend decided to go through my engine harness, which initially looked to be OK. As soon as i started cutting back the hard plastic protection i found several wires had become brittle from years of heat and had broken inside the insulation! It took 3(!) used D-Jet harnesses and a full weekend to make one good harness. That made all the difference in the world and i finally was able to get the engine to run smooth. (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 9th July 2025 - 01:49 PM |
