tumamilhem |
LUFTBRIGADE ![]() ![]() ![]() Group: Members Posts: 1,228 Joined: 29-October 12 From: Jacksonville, FL Member No.: 15,092 Region Association: South East States ![]() |
Apparently the computer in my 1974 2.0 is not working properly and making the car run rich. Does anybody know where I can find another one or who to go to have mine rebuilt? It's for a 1974 2.0 with D-jet fuel injection.
Also my 3rd cylinder is misfiring. Would this have anything to do with the computer? If not, any idea what may be causing it to misfire? I have a new working AAR valve installed, my MPS works, no bad wiring in the wire harness or spark plug wires, the timing and dwell are on point and the valves are adjusted. (IMG:style_emoticons/default/confused24.gif) |
Java2570 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest ![]() |
I'd take Andy's advice above, have your FI harness checked out. Jeff Bowlsby stated that he'd look at it
and test it for you; send him your harness. Even if it's not the root cause, it'll be good for peace of mind later knowing that your wiring is good and not causing an issue with any components. Jon |
Lo-Fi Version | Time is now: 9th July 2025 - 01:27 PM |
