> Kinda Interesting Carb Video, FIXED already, odd problem, solution in bold.
McMark
post Dec 23 2013, 01:28 PM
914 Freak!
Trying to trouble shoot an acceleration lean problem on this set of carbs. So we stuck the GoPro on the back and took a quick test drive. Video confirmed that the pump doesn't squirt as readily/quickly as it should. Still working out the solution, but thought I'd share the video since it's mildly interesting.
https://www.youtube.com/watch?v=XYDmTkNTk3w
Eric_Shea
post Dec 23 2013, 02:19 PM
PMB Performance
What's up with the emulsion tubes?
McMark
post Dec 23 2013, 02:28 PM
914 Freak!
QUOTE(Eric_Shea @ Dec 23 2013, 12:19 PM) *
What're you referring to? The emulsion tube is buried in the carb. You can't see it. The secondary venturi and how the top is dimpled? These are EMPI HPMXs so there's all kinds of little 'things'. (IMG:style_emoticons/default/icon8.gif)
Eric_Shea
post Dec 23 2013, 04:29 PM
PMB Performance
QUOTE(McMark @ Dec 23 2013, 01:28 PM) *
Sorry... Air correction jets that fit over the e-tubes. Are they offset like that on those carbs? Maybe it's just the angle?
McMark   Kinda Interesting Carb Video   Dec 23 2013, 01:28 PM
rhodyguy   wow. sounds terrible. must be undriveable in that ...   Dec 23 2013, 01:33 PM
McMark   wow. sounds terrible. must be undriveable in that...   Dec 23 2013, 02:29 PM
drgchapman   Very Clever!   Dec 23 2013, 01:44 PM
RobW   Very cool. :beer2:   Dec 23 2013, 01:53 PM
Eric_Shea   What's up with the emulsion tubes?   Dec 23 2013, 02:19 PM
McMark   What's up with the emulsion tubes? What...   Dec 23 2013, 02:28 PM
Eric_Shea   What's up with the emulsion tubes? What...   Dec 23 2013, 04:29 PM
ThePaintedMan   Ouch. I've not really heard anything good abou...   Dec 23 2013, 02:41 PM
McMark   Wide angle lens on the GoPro.   Dec 23 2013, 04:32 PM
r_towle   Very neat idea, really. Looks like you have your ...   Dec 23 2013, 04:44 PM
stugray   Now if we could put 4X Go Pros and plot Each barre...   Dec 23 2013, 05:10 PM
tomeric914   Sounds and looks like you have a plugged idle circ...   Dec 23 2013, 05:16 PM
McMark   Not a plugged idle jet. Runs perfectly at idle an...   Dec 23 2013, 06:20 PM
Mike Bellis   Not only do they not squirt right away, they have ...   Dec 23 2013, 06:32 PM
r_towle   Amazing use of a go pro camera.... What did we do ...   Dec 23 2013, 06:35 PM
Eric_Shea   On 40ida3cs you can adjust the cam on the pump and...   Dec 23 2013, 07:02 PM
McMark   These are a pin-through-hole design. No adjustmen...   Dec 23 2013, 07:04 PM
rhodyguy   faulty diaphragm or an issue with the passageway f...   Dec 23 2013, 07:30 PM
McMark   I already knew the diaphragms were pliable and had...   Dec 23 2013, 07:42 PM
Jake Raby   What causes this is replacement pilot valves with ...   Dec 23 2013, 09:50 PM
r_towle   Yah, but the camera thing was cool   Dec 23 2013, 11:14 PM
Eric_Shea   Hey Mark... were you ever able to get this fixed? ...   Dec 24 2013, 10:36 AM
- Lo-Fi Version Time is now: 6th July 2025 - 12:11 PM
