> Kinda Interesting Carb Video, FIXED already, odd problem, solution in bold.
McMark
post Dec 23 2013, 01:28 PM
914 Freak!
Trying to trouble shoot an acceleration lean problem on this set of carbs. So we stuck the GoPro on the back and took a quick test drive. Video confirmed that the pump doesn't squirt as readily/quickly as it should. Still working out the solution, but thought I'd share the video since it's mildly interesting.
https://www.youtube.com/watch?v=XYDmTkNTk3w
stugray
post Dec 23 2013, 05:10 PM
Now if we could put 4X Go Pros and plot Each barrel manifold pressure along with EGTs.....
McMark   Kinda Interesting Carb Video   Dec 23 2013, 01:28 PM
rhodyguy   wow. sounds terrible. must be undriveable in that ...   Dec 23 2013, 01:33 PM
McMark   wow. sounds terrible. must be undriveable in that...   Dec 23 2013, 02:29 PM
drgchapman   Very Clever!   Dec 23 2013, 01:44 PM
RobW   Very cool. :beer2:   Dec 23 2013, 01:53 PM
Eric_Shea   What's up with the emulsion tubes?   Dec 23 2013, 02:19 PM
McMark   What's up with the emulsion tubes? What...   Dec 23 2013, 02:28 PM
Eric_Shea   What's up with the emulsion tubes? What...   Dec 23 2013, 04:29 PM
ThePaintedMan   Ouch. I've not really heard anything good abou...   Dec 23 2013, 02:41 PM
McMark   Wide angle lens on the GoPro.   Dec 23 2013, 04:32 PM
r_towle   Very neat idea, really. Looks like you have your ...   Dec 23 2013, 04:44 PM
stugray   Now if we could put 4X Go Pros and plot Each barre...   Dec 23 2013, 05:10 PM
tomeric914   Sounds and looks like you have a plugged idle circ...   Dec 23 2013, 05:16 PM
McMark   Not a plugged idle jet. Runs perfectly at idle an...   Dec 23 2013, 06:20 PM
Mike Bellis   Not only do they not squirt right away, they have ...   Dec 23 2013, 06:32 PM
r_towle   Amazing use of a go pro camera.... What did we do ...   Dec 23 2013, 06:35 PM
Eric_Shea   On 40ida3cs you can adjust the cam on the pump and...   Dec 23 2013, 07:02 PM
McMark   These are a pin-through-hole design. No adjustmen...   Dec 23 2013, 07:04 PM
rhodyguy   faulty diaphragm or an issue with the passageway f...   Dec 23 2013, 07:30 PM
McMark   I already knew the diaphragms were pliable and had...   Dec 23 2013, 07:42 PM
Jake Raby   What causes this is replacement pilot valves with ...   Dec 23 2013, 09:50 PM
r_towle   Yah, but the camera thing was cool   Dec 23 2013, 11:14 PM
Eric_Shea   Hey Mark... were you ever able to get this fixed? ...   Dec 24 2013, 10:36 AM
- Lo-Fi Version Time is now: 7th July 2025 - 01:59 AM
