| NCRider |
Dec 21 2013, 05:17 PM
Newbie ![]() Group: Members Posts: 18 Joined: 5-June 10 From: Apex NC Member No.: 11,809 Region Association: South East States |
Hi all I'm building my 2270 Raby kit. I might be over thinking this but looking at the way the swivel foot seats on the valve stem is off center. Im thinking this is so that the valve rotates and I should not try and line it up on the valve center line. I can do that if it is necessary. How much offset is to much? I ask because some valves are visually different as far as the off set goes. Also how much clearance should I have between the rocker stack and the end block?
Jeff ![]() |
| r_towle |
Dec 22 2013, 03:54 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
The offset if fine and it's there to turn the valve each fit.
I am curious though, Has anyone checked this setup out to make sure the valve is turning. Who is to say that frictional force would not just turn the swivel foot instead of the valve? Seems like it would be easier to turn that swivel foot, just base on mass, versus all the side friction that is on the valve stem at that moment. |
| Mark Henry |
Dec 23 2013, 09:06 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
The offset if fine and it's there to turn the valve each fit. I am curious though, Has anyone checked this setup out to make sure the valve is turning. Who is to say that frictional force would not just turn the swivel foot instead of the valve? Seems like it would be easier to turn that swivel foot, just base on mass, versus all the side friction that is on the valve stem at that moment. Valve is going to turn no matter what. I grind the keepers so they shouldn't be able to turn, they still do. They at least twist enough that it has never been an issue. |
NCRider Rocker set question? Dec 21 2013, 05:17 PM
Scarlet75
Hi all I'm building my 2270 Raby kit. I might... Dec 21 2013, 05:29 PM
Mark Henry
.....I might be over thinking this.....
Yep. Dec 21 2013, 05:43 PM
NCRider Thanks Mark
".... Doesn't the Raby kit ... Dec 21 2013, 08:49 PM
stugray The offset is ok.
When you are done I would be ve... Dec 22 2013, 10:43 AM
messix I read some where that the valve spring is what in... Dec 23 2013, 11:07 PM
Mark Henry
I read some where that the valve spring is what i... Dec 24 2013, 08:42 AM
gothspeed
I read some where that the valve spring is what i... Dec 24 2013, 11:57 PM
914_teener
[quote name='messix' post='1974279' date='Dec 23 ... Dec 26 2013, 06:15 PM
Jake Raby .004 lateral clearance is perfect for the rocker a... Dec 24 2013, 08:52 AM
NCRider Thanks Jake
I have been playing around with get... Dec 24 2013, 04:58 PM
euro911 If that's your engine, don't forget the lo... Dec 25 2013, 12:19 AM
Jake Raby I prefer the swivel foot a little off center.. Tha... Dec 25 2013, 06:46 AM
stugray I would really like to hear what the valve vs cam ... Dec 25 2013, 01:30 PM
NCRider They are flat stainless steel shims that come in t... Dec 27 2013, 08:53 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:41 PM |
