> help me people!!, have to fix my car
onrails
post Jul 31 2004, 08:52 AM
if the world didn't suck,,we would all fall off
hello everyone! it's been a-while since i've logged in.
{my office computer crashed,,,& i only have AOL at home}
hope all of you are doing fine.
here is my situation,,,,,,,,,
i screwed up (IMG:style_emoticons/default/headbang.gif)
having a-little fun the other night ,,took a left hand turn {sweet curve} intentionally drifted into it,
and went too far. hit the curb w/ my right rear wheel.
now my car handles like a ford pinto!
i can't see any damage to the body
{broken welds,,bent metal etc.}
could i have bent the A arm?
{i think that is what you call the rear suspention console}
if so ,,,i have parts cars i can steal one off of.
just replaced all 4 bushings in the rear last week!
to make it even worse,,,,the wife's car bit the dust
yesterday.
so i have a two seater ,,,a wife,,,& 3 kids
needless to say we're kind-of stuck at home.
will it hurt to drive like this?
if i can find out how,,,it will be fixed this weekend.
thank you in advance,,,,,,
BRIAN
ArtechnikA
post Jul 31 2004, 09:03 AM
rich herzog
QUOTE(onrails @ Jul 31 2004, 06:52 AM)
...hit the curb w/ my right rear wheel.
A-Arms in front; trailing arms in back.
bent trailing arm (at least) is what i'd expect.
you will need to, at minimum, remove the halfshaft, disconnect the bottom of the spring/damper strut, disconnect the caliper and tie it up, remove the trailing arm from the suspension console, do the same to your parts car, re-install the unbent trailing arm, re-assemble in reverse order, set the toe by eys and v-e-r-y caryfully drive it to a 914-aware alignment shop for a rear alignment; call first to make sure they have the appropriate shims (doubt it but it doesn't hurt to call first; there are replacement shims available...)
i'm in approximately the same position, except that the 911 is driveable (low oil pressure) and there are but two of us.
good luck
onrails   help me people!!   Jul 31 2004, 08:52 AM
!   If you can find an alignment shop that KNOWS 914s....   Jul 31 2004, 09:03 AM
ArtechnikA   <...   Jul 31 2004, 09:03 AM
onrails   thanks for the advice,,,good luck w/ the 911 probl...   Jul 31 2004, 09:21 AM
skline   Well, I have not done what you did (so far) and hi...   Jul 31 2004, 10:33 AM
bondo   What's wrong with the wife's car? If there...   Jul 31 2004, 10:52 AM
newdeal2   onrails...what did you paint those tins with? Is t...   Jul 31 2004, 11:46 AM
onrails   yes,, it is the same color as the car,,,,,painted ...   Jul 31 2004, 04:38 PM
onrails   um,,,,,acrylic enamel   Jul 31 2004, 04:39 PM
- Lo-Fi Version Time is now: 12th March 2026 - 01:48 PM
