scottb |
who wants a PEZ?! ![]() ![]() ![]() Group: Members Posts: 1,993 Joined: 27-December 02 From: south-(not north)-wick, MA Member No.: 32 Region Association: North East States ![]() |
until just a couple of days ago, the tranny shifted very well without any trouble. however, now i have the following issues:
UP 1st to 2nd = hard shift. almost like the gear is locked out (gear grind smiley) 2nd to 3rd = same as 1st to 2nd (IMG:style_emoticons/default/mad.gif) 3rd to 4th = fine 4th to 5th = fine DOWN 5th to 4th = fine 4th to 3rd = fine 3rd to 2nd = hard shift as above. (IMG:style_emoticons/default/mad.gif) 2nd to 1st = fine any suggestions on where i should start looking? i recently changed out my bushings so that has been done. thanks in advance..... |
ejm |
I can see the light at the end of the tunnel ![]() ![]() ![]() ![]() Group: Members Posts: 2,707 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None ![]() |
QUOTE(scottb @ Jul 31 2004, 04:48 AM) (gear grind smiley) If your grinding into gears the clutch might not be fully releasing. The cable may be stretching or the tube could have come loose. How is the shift into reverse? How do the problem gears shift with the engine not running? |
Lo-Fi Version | Time is now: 1st August 2025 - 06:14 AM |
