trailing arm washer, does anyone repro these.? it is a rubber washer |
DRPHIL914 |
Jan 4 2014, 09:57 PM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Its the washer on the end of the pivot shaft that would go between it and the suspension ear
Its #8 in this diagram Attached image(s) |
bdstone914 |
Jan 4 2014, 10:07 PM
bdstone914 Group: Members Posts: 4,538 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Its the washer on the end of the pivot shaft that would go between it and the suspension ear Its #8 in this diagram Even though it is shown in PET I have never seen one and have removed many trailing arms. There is really no room for a washer on the end of the pivot shaft. The end of the nut is nearly flush with the end of the shaft. |
DRPHIL914 |
Jan 4 2014, 10:15 PM
Its the washer on the end of the pivot shaft that would go between it and the suspension ear Its #8 in this diagram Even though it is shown in PET I have never seen one and have removed many trailing arms. There is really no room for a washer on the end of the pivot shaft. The end of the nut is nearly flush with the end of the shaft. Well I just removed mine today-there is a rubber washer the size of the trailing arm surface at the end of the trailing arm. The original one is in pretty tuff shape. I am sure this arm has never been off this car by the looks of the condition of the under coat that is on the nuts bolts and other parts. Also without this the arm surface would be hard against the suspension ear rubbing metal on metal as the arm pivots with the suspension movement. |
Lo-Fi Version | Time is now: 11th June 2024 - 10:01 AM |
