Engine exploration...., Is this engine any good? |
bostonmeche |
Jul 31 2004, 03:27 PM
1974 914-4 (some day a Suby conversion) Group: Members Posts: 39 Joined: 30-December 02 From: Easton, MA Member No.: 44 Region Association: North East States |
Hi all,
Well after pulling the engine several weeks ago and asking retarded questions about push rod tubes, and oil geysers, I done n pulled the cylinder head off of #3 and #4. Having done this I was finally able to learn some things. 1. My cylinders are 96mm in dia and 76mm stroke, (I get 2.2L) Yeah! (IMG:style_emoticons/default/driving.gif) 2. My engine doesn't look like the prestine engines I see on all the Discovery Channel TV shows like Rides and Overhaulin. (IMG:style_emoticons/default/sad.gif) So my questions to those who know. 1) Is it normal to have all this black cryosote (sp?) looking stuff all over the pistons and valves? 2) Should I just put this thing back together and quietly walk away and call the engine toast? or should I clean all the crude off and try and put it back together? 3) My compression numbers are: Cyl #1 100 Cyl #2 85 Cyl #3 100 Cyl #4 75 4) Is this engine worth fix'n?? Attached thumbnail(s) |
SirAndy |
Jul 31 2004, 10:57 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
yupp, 96 means you got a 2056, valves are bigger than stock.
this *does* look like a keeper! the crud is not too bad and can be cleaned easily. the compression is *bad*. my engine has 150-160 on all 4. nothing a set of new rings couldn't fix. big valves and big pistons are guud! (IMG:style_emoticons/default/wink.gif) Andy |
Lo-Fi Version | Time is now: 3rd June 2024 - 04:07 AM |
