trailing arm washer, does anyone repro these.? it is a rubber washer |
DRPHIL914 |
Jan 4 2014, 09:57 PM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Its the washer on the end of the pivot shaft that would go between it and the suspension ear
Its #8 in this diagram Attached image(s) |
scotty b |
Jan 5 2014, 08:41 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
NO rubber washer in between the suspension ear and the arm. The bushing inside the arm is supposed to cover to the end of the shaft. #8 in the diagram is most likely the metal washer on the OUTSIDE of the suspension ear under the nut
DRPHIL914 |
Jan 5 2014, 08:50 PM
NO rubber washer in between the suspension ear and the arm. The bushing inside the arm is supposed to cover to the end of the shaft. #8 in the diagram is most likely the metal washer on the OUTSIDE of the suspension ear under the nut Well that is interesting. Except the ones I took off had no washer on the outside.do I need to source one? |
scotty b |
Jan 5 2014, 08:54 PM
NO rubber washer in between the suspension ear and the arm. The bushing inside the arm is supposed to cover to the end of the shaft. #8 in the diagram is most likely the metal washer on the OUTSIDE of the suspension ear under the nut Well that is interesting. Except the ones I took off had no washer on the outside.do I need to source one? I'm not sure it is necessary. I've stripped down some cars that had a washer and some that didn't. FWIW it's a lock washer, not a flat one. Also I'm ASSUMING that is what is being shown in the diagram as I have probably dropped 20+ suspensions and have NEVER encountered a rubber washer (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 11th June 2024 - 02:53 AM |
