Engine exploration...., Is this engine any good? |
bostonmeche |
Jul 31 2004, 03:27 PM
1974 914-4 (some day a Suby conversion) Group: Members Posts: 39 Joined: 30-December 02 From: Easton, MA Member No.: 44 Region Association: North East States |
Hi all,
Well after pulling the engine several weeks ago and asking retarded questions about push rod tubes, and oil geysers, I done n pulled the cylinder head off of #3 and #4. Having done this I was finally able to learn some things. 1. My cylinders are 96mm in dia and 76mm stroke, (I get 2.2L) Yeah! (IMG:style_emoticons/default/driving.gif) 2. My engine doesn't look like the prestine engines I see on all the Discovery Channel TV shows like Rides and Overhaulin. (IMG:style_emoticons/default/sad.gif) So my questions to those who know. 1) Is it normal to have all this black cryosote (sp?) looking stuff all over the pistons and valves? 2) Should I just put this thing back together and quietly walk away and call the engine toast? or should I clean all the crude off and try and put it back together? 3) My compression numbers are: Cyl #1 100 Cyl #2 85 Cyl #3 100 Cyl #4 75 4) Is this engine worth fix'n?? Attached thumbnail(s) |
McMark |
Aug 1 2004, 12:45 PM
The oil will sit on the bottom of the cylinder and not do much. The BMW has relatively vertical cylinders to oil will distribute evenly around the ring and help seal.
Lo-Fi Version | Time is now: 3rd June 2024 - 02:52 AM |
