Engine exploration...., Is this engine any good? |
bostonmeche |
Jul 31 2004, 03:27 PM
1974 914-4 (some day a Suby conversion) Group: Members Posts: 39 Joined: 30-December 02 From: Easton, MA Member No.: 44 Region Association: North East States |
Hi all,
Well after pulling the engine several weeks ago and asking retarded questions about push rod tubes, and oil geysers, I done n pulled the cylinder head off of #3 and #4. Having done this I was finally able to learn some things. 1. My cylinders are 96mm in dia and 76mm stroke, (I get 2.2L) Yeah! (IMG:style_emoticons/default/driving.gif) 2. My engine doesn't look like the prestine engines I see on all the Discovery Channel TV shows like Rides and Overhaulin. (IMG:style_emoticons/default/sad.gif) So my questions to those who know. 1) Is it normal to have all this black cryosote (sp?) looking stuff all over the pistons and valves? 2) Should I just put this thing back together and quietly walk away and call the engine toast? or should I clean all the crude off and try and put it back together? 3) My compression numbers are: Cyl #1 100 Cyl #2 85 Cyl #3 100 Cyl #4 75 4) Is this engine worth fix'n?? Attached thumbnail(s) |
ArtechnikA |
Aug 1 2004, 12:48 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
QUOTE(anthony @ Aug 1 2004, 10:39 AM) Does squirting oil in the cylinder when doing a compression check work on type IVs. I never hear of anyone doing this on type IVs. On my old bmw 320i engine it was recommended... it's not as effective on flat engines, which is why a compression test is typically followed by a leakdown test to determine the extent of the leaksge and - by listening to the escaping air you can tell the location of the leakage. |
Lo-Fi Version | Time is now: 3rd June 2024 - 03:48 AM |
