Type IV upgrades and FI, Where's the cut-off to carbs? |
boxsterfan |
Jan 7 2014, 12:42 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
At some point, my motor (1974 2.0L) will need a rebuild. I'm not going to go the /6 conversion on this car. If I rebuild the motor to a 2056 or 2270 displacement, can I still use the FI system (D-jet)? Or is there some spot in here where it is better to switch to carbs? Or if I wanted to have FI then switching to L-Jet instead?
Happy to do some reading if you have it... (IMG:style_emoticons/default/chowtime.gif) |
rhodyguy |
Jan 9 2014, 08:38 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
BMWs used Ljet as well. your 2.0 heads have 3 studs to attach the intake manifolds. stock Ljet manifolds have 4 so some adaptation would be required. going 2270 big? think carbs or aftermarket dual throttle bodies. bring a pile of c-notes and a bottle of aspirin.
ClayPerrine |
Jan 9 2014, 08:57 AM
Life's been good to me so far..... Group: Admin Posts: 15,512 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
BMWs used Ljet as well. your 2.0 heads have 3 studs to attach the intake manifolds. stock Ljet manifolds have 4 so some adaptation would be required. going 2270 big? think carbs or aftermarket dual throttle bodies. bring a pile of c-notes and a bottle of aspirin. You can use the 3 bolt intake runners with the L-Jet system. I have done it. |
Lo-Fi Version | Time is now: 7th June 2024 - 12:20 AM |
