Brake Lines routing and configuration, the dreaded SS brake lines!! |
Seabird |
Jan 6 2014, 10:24 AM
Member Group: Members Posts: 165 Joined: 21-November 13 From: United States Member No.: 16,683 Region Association: South East States |
I am not looking to discuss the value of SS over OEM rubber so lets leave that out. I will be running SS lines. This is a track car and the lines and the rest of the car will get inspected before every track weekend.
I am doing the maintenance to the braking system on my new track car. The PO did a five lug swap front and rear. Front is from a 911 and the rear seems to use the 944 half shafts. They way the brake lines are configured is ridged line to flex line back to ridged line. In the front the final ridged line is tucked away between the rotor dust cover and the strut tube. In the rear the rigid line follows the trailing arm and the turns down and up in to the caliper. Looks like it has a different attachment point than the stock on the trailing arm. (IMG:http://www.914world.com/bbs2/uploads_offsite/dl.dropboxusercontent.com-16683-1389025463.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/dl.dropboxusercontent.com-16683-1389025466.2.jpg) Question 1: I am not happy at all with the rear configuration. Looks totally unsafe; the picture really does not show just how low and unprotected it is but its the only one I have at the moment. So I am looking to change that out and am looking for recommendations. In general I don't like the added failure points of the extra ridged lines and their connections. I especially don't like having to flex the ridged lines back and forth to service the calipers, rotors, bearings, etc.... At some point metal fatigue will effect them. Question 2: Are there any racers running flex lines from the chassis to the calipers? I would like to see how you realized this. Thanks, Miguel |
andrew15 |
Jan 11 2014, 01:42 PM
Newbie Group: Members Posts: 40 Joined: 10-April 10 From: Thunder Bay, ON Member No.: 11,594 Region Association: None |
I'm using full braided lines on my ChumpCar 914 project.
A guy I know that competes in the Canadian Rally Championship runs his Subi with these lines and good enough for him = good enough for me. I ordered the lines from Pegasus - Basically Goodridge AN3 hoses with 10mm banjo at the m/c end and female AN3 on the other end. Add some various T fittings and some AN3 adapter fittings for the calipers and you're set. There were a couple reasons for me to do the switch - - I'm tracking a 40yr old rusty 914 and didn't trust the old lines - Cost was about the same as new hard lines + flex lines - Full braided lines mean only I only have 1/3 - 1/2 the connections vs oem hard / flex lines - Easy to replace and I can have a set of spares in the truck Regards, AM |
Lo-Fi Version | Time is now: 10th June 2024 - 10:29 AM |
