> No Power Captain!, 74 914 2L runs for 10 minutes then dies ?????
thompson-mfr
post Jan 14 2014, 01:15 PM
Thompson, Ryan
Ok, I have been fighting some electrical gremlins.
74 2.0L FI 037 brain (now with 270 ohm ballast resistor)
The car runs great for 10-15 minutes then dies.
I tested the power relay and fuel pump relay and fuel pump itself and have power to all.
After it cools off for 3-5 minutes it will start again.
I have not checked for spark, but am guessing when it dies this is what is stopping.
What could this be??? ECU / Brain / Computer? I know they rarely fail
When I unplug my air intake sensor it has no affect on running. I thought maybe another sign of potentially a bad ecu / brain / computer. I have read it is supposed to richen the mixture.
Here is a pic of my car just because I like threads with pictures.
thompson-mfr   No Power Captain!   Jan 14 2014, 01:15 PM
boxsterfan   Points or electronic ignition? Possibly a bad coi...   Jan 14 2014, 01:43 PM
DBCooper   Fuel filter, pump, tank outlet or some other restr...   Jan 14 2014, 01:45 PM
Jeffs9146   CHTS (Cylinder Head Temp Sensor) Or AAR (Aux Air R...   Jan 14 2014, 04:44 PM
injunmort   coil, and they do go bad. runs fine cold, as engi...   Jan 14 2014, 05:19 PM
thompson-mfr   coil, and they do go bad. runs fine cold, as eng...   Jan 15 2014, 07:27 PM
914_teener   Go to the Anders site and use the flow chart as s...   Jan 14 2014, 05:29 PM
iamchappy   Temp II sensor. Try jumping the fuel pump relay an...   Jan 14 2014, 05:32 PM
thompson-mfr   Temp II sensor. Try jumping the fuel pump relay a...   Jan 15 2014, 07:20 PM
Dave_Darling   Intake air temp sensor has a small effect on mixtu...   Jan 14 2014, 05:40 PM
turk22   vapor lock?   Jan 14 2014, 06:59 PM
cary   How does it die ???? Spitter... Sputter. Or off li...   Jan 14 2014, 10:10 PM
thompson-mfr   How does it die ???? Spitter... Sputter. Or off l...   Jan 15 2014, 07:22 PM
falcor75   My bet is faulty gas cap (try runnning it with the...   Jan 14 2014, 11:23 PM
Rockaria   When I rebuilt my 73 2.0FI I had the same exact pr...   Jan 15 2014, 09:23 AM
914_teener   That just goes back to the adage with D-jet that y...   Jan 15 2014, 09:37 AM
7TPorsh   not to hijack the thread but...I have this same ty...   Jan 15 2014, 10:17 AM
mrholland2   When this happened to me, it was crud in the fuel ...   Jan 15 2014, 01:09 PM
boxsterfan   Try borrowing a coil from another member here. Als...   Jan 15 2014, 07:25 PM
Jeffs9146   CHTS..........Just saying!! :chair:   Jan 15 2014, 07:28 PM
thompson-mfr   Thanks to all for the numerous suggestions. I can...   Jan 15 2014, 07:32 PM
thompson-mfr   I tested the Coil and it has power when the car di...   Jan 28 2014, 01:57 PM
stugray   I had this exact thing happen to me driving from...   Jan 28 2014, 06:35 PM
DBCooper   It's almost certainly fuel. You have some blo...   Jan 28 2014, 08:42 PM
- Lo-Fi Version Time is now: 2nd May 2026 - 02:32 PM
