FS: 2.0L FI pkg., * SOLD * |
914werke |
Oct 14 2012, 11:27 AM
"I got blisters on me fingers" Group: Members Posts: 10,087 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Here is a COMPLETE OE D-Jet FI package off of a 1976
Items you want to ensure you get in any kit (too often combinations are offered but omitting specific pieces) include: Electronic Control Unit & Bracket Injection harness Manifold pressure sensor Distributor (w/trigger points & vacuum advance) Cylinder head temp Sensor Fuel pressure regulator Intake runners (x2) Plenum (correct for MY) Air box (correct for MY) Oil fill tower (with PCV valve->74) Fuel injectors (x4 Green 2.0L, Yellow=1.7L) Fuel injector clamps (x4) Fuel line clamps (x14 OE w/rolled shoulder) Fuel rails (x1 straight, x1 T'd) Flashback valve (->74) Deceleration valve Throttle body Throttle position switch Thermo-time switch (specific to MY) Cold start injector Intake air temp sensor Auxiliary air valve High pressure Fuel Pump Consumables (items not necessarily included & you'd probably want to replace): Fuel Filter Fuel Lines (7.5mm) Air Filter Throttle Body Gasket Vacuum lines (various size & length) Injector seals (4) PCV valve (depending on MY, if you can find one, otherwise disassemble clean & reuse) Intake / plenum seals (4) Phenolic spacers (2) Late cars had additional emission equipment, Air pump Brackets & piping CA cars had further plumbing and electronic Gee-Gaa's including a specific Gauge bezel with idiot lights, Dual speedo cables with trip computer EGR sensor in a dual chamber muffler EGR piping to that muffler Attached thumbnail(s) Attached image(s) |
914werke |
Jan 15 2014, 10:17 AM
Lo-Fi Version | Time is now: 23rd May 2024 - 03:52 PM |
