| thompson-mfr |
Jan 14 2014, 01:15 PM
Thompson, Ryan ![]() ![]() Group: Members Posts: 198 Joined: 30-September 08 From: Silverton, OR Member No.: 9,598 Region Association: Pacific Northwest |
Ok, I have been fighting some electrical gremlins.
74 2.0L FI 037 brain (now with 270 ohm ballast resistor) The car runs great for 10-15 minutes then dies. I tested the power relay and fuel pump relay and fuel pump itself and have power to all. After it cools off for 3-5 minutes it will start again. I have not checked for spark, but am guessing when it dies this is what is stopping. What could this be??? ECU / Brain / Computer? I know they rarely fail When I unplug my air intake sensor it has no affect on running. I thought maybe another sign of potentially a bad ecu / brain / computer. I have read it is supposed to richen the mixture. Here is a pic of my car just because I like threads with pictures. |
| boxsterfan |
Jan 15 2014, 07:25 PM
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Try borrowing a coil from another member here. Also, have a look at your fuel filter and see if it is clogged.
thompson-mfr No Power Captain! Jan 14 2014, 01:15 PM
boxsterfan Points or electronic ignition?
Possibly a bad coi... Jan 14 2014, 01:43 PM
DBCooper Fuel filter, pump, tank outlet or some other restr... Jan 14 2014, 01:45 PM
Jeffs9146 CHTS (Cylinder Head Temp Sensor)
Or
AAR (Aux Air R... Jan 14 2014, 04:44 PM
injunmort coil, and they do go bad. runs fine cold, as engi... Jan 14 2014, 05:19 PM
thompson-mfr
coil, and they do go bad. runs fine cold, as eng... Jan 15 2014, 07:27 PM
914_teener Go to the Anders site and use the flow chart as s... Jan 14 2014, 05:29 PM
iamchappy Temp II sensor. Try jumping the fuel pump relay an... Jan 14 2014, 05:32 PM
thompson-mfr
Temp II sensor. Try jumping the fuel pump relay a... Jan 15 2014, 07:20 PM
Dave_Darling Intake air temp sensor has a small effect on mixtu... Jan 14 2014, 05:40 PM
turk22 vapor lock? Jan 14 2014, 06:59 PM
cary How does it die ????
Spitter... Sputter.
Or off li... Jan 14 2014, 10:10 PM
thompson-mfr
Spitter... Sputter.
Or off l... Jan 15 2014, 07:22 PM
falcor75 My bet is faulty gas cap (try runnning it with the... Jan 14 2014, 11:23 PM
Rockaria When I rebuilt my 73 2.0FI I had the same exact pr... Jan 15 2014, 09:23 AM
914_teener That just goes back to the adage with D-jet that y... Jan 15 2014, 09:37 AM
7TPorsh not to hijack the thread but...I have this same ty... Jan 15 2014, 10:17 AM
mrholland2 When this happened to me, it was crud in the fuel ... Jan 15 2014, 01:09 PM
Jeffs9146 CHTS..........Just saying!! :chair: Jan 15 2014, 07:28 PM
thompson-mfr Thanks to all for the numerous suggestions. I can... Jan 15 2014, 07:32 PM
thompson-mfr I tested the Coil and it has power when the car di... Jan 28 2014, 01:57 PM
stugray
I had this exact thing happen to me driving from... Jan 28 2014, 06:35 PM
DBCooper It's almost certainly fuel. You have some blo... Jan 28 2014, 08:42 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd May 2026 - 02:33 PM |
