| thompson-mfr |
Jan 14 2014, 01:15 PM
Thompson, Ryan ![]() ![]() Group: Members Posts: 198 Joined: 30-September 08 From: Silverton, OR Member No.: 9,598 Region Association: Pacific Northwest |
Ok, I have been fighting some electrical gremlins.
74 2.0L FI 037 brain (now with 270 ohm ballast resistor) The car runs great for 10-15 minutes then dies. I tested the power relay and fuel pump relay and fuel pump itself and have power to all. After it cools off for 3-5 minutes it will start again. I have not checked for spark, but am guessing when it dies this is what is stopping. What could this be??? ECU / Brain / Computer? I know they rarely fail When I unplug my air intake sensor it has no affect on running. I thought maybe another sign of potentially a bad ecu / brain / computer. I have read it is supposed to richen the mixture. Here is a pic of my car just because I like threads with pictures. |
| injunmort |
Jan 14 2014, 05:19 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
coil, and they do go bad. runs fine cold, as engine warms up, coil expands,windings separate discharge breaks down. cheap easy check before getting into chasing sparks in the dark, swap coils and rule it out first.
| thompson-mfr |
Jan 15 2014, 07:27 PM
coil, and they do go bad. runs fine cold, as engine warms up, coil expands,windings separate discharge breaks down. cheap easy check before getting into chasing sparks in the dark, swap coils and rule it out first. good suggestion! I didn't think of this. My coil only has 15,000 miles on it and is shiny new looking, so didn't even consider it. Then again, that is over 7 years. That would be a cheap easy fix. |
thompson-mfr No Power Captain! Jan 14 2014, 01:15 PM
boxsterfan Points or electronic ignition?
Possibly a bad coi... Jan 14 2014, 01:43 PM
DBCooper Fuel filter, pump, tank outlet or some other restr... Jan 14 2014, 01:45 PM
Jeffs9146 CHTS (Cylinder Head Temp Sensor)
Or
AAR (Aux Air R... Jan 14 2014, 04:44 PM
914_teener Go to the Anders site and use the flow chart as s... Jan 14 2014, 05:29 PM
iamchappy Temp II sensor. Try jumping the fuel pump relay an... Jan 14 2014, 05:32 PM
thompson-mfr
Temp II sensor. Try jumping the fuel pump relay a... Jan 15 2014, 07:20 PM
Dave_Darling Intake air temp sensor has a small effect on mixtu... Jan 14 2014, 05:40 PM
turk22 vapor lock? Jan 14 2014, 06:59 PM
cary How does it die ????
Spitter... Sputter.
Or off li... Jan 14 2014, 10:10 PM
thompson-mfr
Spitter... Sputter.
Or off l... Jan 15 2014, 07:22 PM
falcor75 My bet is faulty gas cap (try runnning it with the... Jan 14 2014, 11:23 PM
Rockaria When I rebuilt my 73 2.0FI I had the same exact pr... Jan 15 2014, 09:23 AM
914_teener That just goes back to the adage with D-jet that y... Jan 15 2014, 09:37 AM
7TPorsh not to hijack the thread but...I have this same ty... Jan 15 2014, 10:17 AM
mrholland2 When this happened to me, it was crud in the fuel ... Jan 15 2014, 01:09 PM
boxsterfan Try borrowing a coil from another member here. Als... Jan 15 2014, 07:25 PM
Jeffs9146 CHTS..........Just saying!! :chair: Jan 15 2014, 07:28 PM
thompson-mfr Thanks to all for the numerous suggestions. I can... Jan 15 2014, 07:32 PM
thompson-mfr I tested the Coil and it has power when the car di... Jan 28 2014, 01:57 PM
stugray
I had this exact thing happen to me driving from... Jan 28 2014, 06:35 PM
DBCooper It's almost certainly fuel. You have some blo... Jan 28 2014, 08:42 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd May 2026 - 02:32 PM |
