valve guide head interface clearance, How much plus |
Joe Ricard |
Aug 2 2004, 07:45 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
So the Machinist says that the new intake valve is .039 larger than the hole it is supposed to go into. What is the size +.000 to put the guide in. 2.0L head. And I guess I have the wrong Exhaust. Need 15mm guide vice 13mm
Gosh this is fun (IMG:style_emoticons/default/rolleyes.gif) |
ArtechnikA |
Aug 2 2004, 09:06 AM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
QUOTE(Joe Ricard @ Aug 2 2004, 06:50 AM) Art, I have no idea what you said. In simple terms how much do I need to take off the outside diameter of the valve guide to achieve the correct fit with respect to the bore in the head. originally, you said " the new intake valve is .039 larger than the hole it is supposed to go into. " which i took to mean the valve stem is too big to fit the installed guide. (valve is larger than its hole - i donno how else to interpret that ...) i think you're now asking for the size difference of the OD of the UNinstalled guide to the ID of the guide hole in the head to achieve the proper shrink/press fit. i have no idea, and i doubt the Spec Book or Haynes would be reliable on this matter, since techniques and valve guide materials have changed so much in the intervening 30 years. hopefully someone with a track record of successful valve guide replacement wil be able to chime in; this is an area of head work i've never even attempted. who's Art ? |
Lo-Fi Version | Time is now: 1st June 2024 - 08:08 AM |
