| Dtjaden |
Jan 16 2014, 11:19 PM
Member ![]() ![]() Group: Members Posts: 232 Joined: 25-May 13 From: Morgan Hill, CA Member No.: 15,915 Region Association: Northern California |
I started this process a couple of months ago - in time for Dr. Evil's transmission rebuild clinic at McMark's but as a newbie and for other newbies I thought that I would document what I am doing. This may help out some newer World members but, for my benefit, hopefully some old timers can set me straight when I veer off track.
I started this because the 1.7L 914 I purchased in June had an engine that was down on power and leaked a SIGNIFICANT amount of oil. I also was not happy with the dual Weber IDF carbs so I plan to replace them with FI. A few months ago I found a 2.0L engine for sale a few miles from me so I picked that up to be the basis of the rebuild. That engine was not running and had not run for a few years. Depending on the condition of the crankshaft I will be building either a 2056 CC engine if the crank is good or a 2270 CC engine if the crank needs to be replaced. My first step was to determine the problems with the engine. While the crank would move it would not turn through a full rotation. I removed all of the engine tins and then the heads. I found that the number 4 cylinder had dropped its valve seat. It was captive and had hammered into the head. I had the heads cleaned and lightly bead blasted at a local engine builder. I emailed requests to a number of well known machine shops that specialize in 914/VW Type 4 head work (EMW, Brothers Machine, Headflow Masters and HAM). After a few days I have heard from two of those, Brothers and Headflow. Adrian at Headflow Masters has a very good reputation so I will most likely use them for the work. I plan new valves, seats, springs, the exhaust port repair and the repair of hairline cracks around 3 of the spark plug bores. The heads will also be lightly ported and polished. Continuing with the tear-down today, I split the case Virtually everything in the engine will be replaced including the cam, pistons and cylinders, oil pump. I will use the existing connecting rods if they meet spec. ![]() ![]() ![]() Tomorrow the case and other exterior parts will be off the be cleaned at the local machine shop. |
| cegallegos99 |
Jan 17 2014, 10:09 PM
Newbie ![]() Group: Members Posts: 20 Joined: 23-December 13 From: lafayette, la Member No.: 16,790 Region Association: None |
Hi,
does anyone know of a good engine rebuilder in Houston? I am away from home often. |
Dtjaden 2.0L Engine Rebuild (Yes another one) Jan 16 2014, 11:19 PM
Dtjaden I started looking at the various parts and did som... Jan 17 2014, 05:37 PM
toadman Thank you for documenting your rebuild. I am not ... Jan 18 2014, 09:40 AM
Dtjaden Thanks for your comment toadman. I started down th... Jan 18 2014, 11:50 AM
stugray
You mean "rockers" and since you have ... Jan 18 2014, 12:13 PM
Dtjaden
You mean "rockers" and since you have... Jan 18 2014, 05:55 PM
toadman Very interesting. I will follow this thread close... Jan 19 2014, 04:39 PM
Nozzle
Very interesting. I will follow this thread clos... Jan 19 2014, 05:10 PM
toadman Nozzle, thank you for this information. It is muc... Jan 20 2014, 08:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th April 2026 - 04:26 AM |
