| Nozzle |
Jan 18 2014, 04:01 PM
Member ![]() ![]() Group: Members Posts: 158 Joined: 6-November 08 From: Lexington Park, Maryland Member No.: 9,725 Region Association: MidAtlantic Region |
Quick background: With 100k miles on the car, previous owner had motor rebuilt back in 1985. Engine now has about 30K miles and started blowing oil into the intake plenum bigtime and running poorly. I checked the compression and got 73 PSI in cylinder three with 145-150 in the others. Did a valve adjustment (most were slightly tight but not bad) and compression came up to 80 PSI in number three with the others staying about the same.
Dropped the engine today, pulled the head on cylinders 3 and 4 and here's what I found: Combustion chamber #3 cylinder Here's chamber for #4 cylinder for comparison Not sure if it's related but exhaust valve spring for cylinder #3 was discolored with what looks like burned oil while the rest looked nice and shiny Cylinder 3 piston and bore And cylinder 4 piston for comparision I'm thinking leaking rings on cylinder 3 is the cause of the oil in the plenum and inside the cylinders as the valves in that cylinder seem to look OK unless I'm mission something. Very interesting in hearing any thoughts as this my first time going inside the engine like this. Thanks, John |
| r_towle |
Jan 19 2014, 02:46 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Pull the cylinder off and have a towel underneath to catch pieces of the ring.
See if you have a broken ring or broken ring land on that piston. It's simple enough to use a proper ring compressor to put the cylinder back onto that piston, or pull the piston and do that on the bench, then insert the wrist pin into the piston while it hags out of the bottom of the cylinder... Keep digging. |
Nozzle OK so I got the cylinder head off... Jan 18 2014, 04:01 PM
Mike Bellis Bad rings shouldn't blow a lot of oil into the... Jan 18 2014, 05:01 PM
Joe Sharp Well John, I would say your correct. Looks like oi... Jan 18 2014, 05:07 PM
jimkelly I know nothing about nothing but does it appear pi... Jan 18 2014, 05:10 PM
Dr Evil More than one thing wrong here. Valve guide is lik... Jan 18 2014, 05:12 PM
Nozzle The rebuild was done by a supposedly reputable ind... Jan 18 2014, 06:37 PM
somd914
My current theory is rings in number 3 are shot ... Jan 18 2014, 06:52 PM
Cap'n Krusty
The rebuild was done by a supposedly reputable in... Jan 18 2014, 09:12 PM
somd914 Well the good news is the engine drop went quickly... Jan 18 2014, 06:44 PM
r_towle Pull the hose from the PVC valve, and post a pic.
... Jan 18 2014, 08:39 PM
Nozzle
Pull the hose from the PVC valve, and post a pic.... Jan 19 2014, 09:40 AM
tracks914 Quick check. Turn the head upside down.Secure it. ... Jan 19 2014, 09:38 PM![]() ![]() |
Lo-Fi Version | Time is now: 5th October 2026 - 03:56 PM |
