> OK so I got the cylinder head off..., ...But need some help understanding what I'm seeing.
Nozzle
post Jan 18 2014, 04:01 PM
Quick background: With 100k miles on the car, previous owner had motor rebuilt back in 1985. Engine now has about 30K miles and started blowing oil into the intake plenum bigtime and running poorly. I checked the compression and got 73 PSI in cylinder three with 145-150 in the others. Did a valve adjustment (most were slightly tight but not bad) and compression came up to 80 PSI in number three with the others staying about the same.
Dropped the engine today, pulled the head on cylinders 3 and 4 and here's what I found:
Combustion chamber #3 cylinder
Here's chamber for #4 cylinder for comparison
Not sure if it's related but exhaust valve spring for cylinder #3 was discolored with what looks like burned oil while the rest looked nice and shiny
Cylinder 3 piston and bore
And cylinder 4 piston for comparision
I'm thinking leaking rings on cylinder 3 is the cause of the oil in the plenum and inside the cylinders as the valves in that cylinder seem to look OK unless I'm mission something. Very interesting in hearing any thoughts as this my first time going inside the engine like this.
Thanks,
John
tracks914
post Jan 19 2014, 09:38 PM
Canadian Member
Quick check. Turn the head upside down.Secure it. Pour a bit of varsol into the head. See if any of it leaks past the closed valves.
That and look for broken rings.
- Lo-Fi Version Time is now: 5th October 2026 - 03:56 PM
