> Can YOU test this for me?, resistance vs. temp for stock IAT
McMark
post Jan 20 2014, 06:53 PM
914 Freak!
I haven't been able to find a good graph of the resistance vs. temp for the stock D-Jet intake air temp sensor (IAT). I've never had very good luck trying to measure it directly (hot oil bath with a multimeter). Has anyone done this? Seen a graph (factory or made by someone)? Or is anyone set up to conduct this type of test with accuracy? I can provide the sensor with a wiring pigtail if so. (IMG:style_emoticons/default/beerchug.gif)
McMark
post Jan 20 2014, 10:35 PM
914 Freak!
(IMG:http://www.914world.com/bbs2/uploads_offsite/web.archive.org-419-1390278956.1.gif)
SWEET! Thanks Dave!
JamesM
post Jan 21 2014, 01:52 PM
Mark,
If this is to be used with Megasquirt, it can be done and works well. The only issue to be aware of is that due to the sensor being solid/non insulated, and in direct contact with the plenum which is in direct contact with the case, heat-soak of the sensor can be an issue. This becomes really apparent when you try and re-start a hot car after it has been sitting.
Thankfully the newer MSextra versions have a lot of things you can adjust to compensate for this.
-James
- Lo-Fi Version Time is now: 11th July 2025 - 01:12 PM
