> 73 D-Jet 3 port fuel pump, Is my fuel flowing right ??
David_S
post Jan 23 2014, 02:08 AM
I decided that before I installed and plumbed my fuel pump that it may be a good idea to mess with it on the bench first. My fuel pump is on the bench and hot wiring it direct to a battery for power. If I use the "S" port for suction, I get no flow from the "D" port, and lots of flow from the "R" port. Is this right since it cant build any kind of pressure right now, or should I be getting fuel out of the "D" port instead of "R" ?? The fuel pump is all that I need to see if this thing will run again !!! Thanks in advance !!
David_S
post Jan 23 2014, 09:07 AM
I read that one last night, but it still doesn't explain why Iam not getting any fuel from the "D" port. If I am understanding the operation right, I should be getting flow out of the "D" port (to pressurize the fuel rails) and not the "R" port (to return fuel back to the tank). The way that it is working right now, my pump is sucking from the tank ("S" port), and just returning fuel back to the tank ("R" port), and not letting the system pressure up ("D" port).
- Lo-Fi Version Time is now: 6th July 2025 - 11:32 AM
