David_S |
Member ![]() ![]() Group: Members Posts: 430 Joined: 11-May 03 From: Dimmitt, Tx Member No.: 680 Region Association: Southwest Region ![]() |
I decided that before I installed and plumbed my fuel pump that it may be a good idea to mess with it on the bench first. My fuel pump is on the bench and hot wiring it direct to a battery for power. If I use the "S" port for suction, I get no flow from the "D" port, and lots of flow from the "R" port. Is this right since it cant build any kind of pressure right now, or should I be getting fuel out of the "D" port instead of "R" ?? The fuel pump is all that I need to see if this thing will run again !!! Thanks in advance !!
David_S |
Blockage in the D port could be a possibility. I had the S port in my fuel jug, and the D port and R port were open with no T. When I powered the pump, I got fuel out of R and nothing out of D. I tried to block R and it would pressure up just like I think the D should pressure up. Hope that makes sense ......
Lo-Fi Version | Time is now: 6th July 2025 - 02:17 PM |
