How to cut steel pushrods, Valve Train Set-Up |
Highland |
Jan 23 2014, 09:25 AM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
How to most people get their pushrods cut? Should I take the pushrods to the same machinest that worked on my engine parts (crank, cylinders, rods,...) or to a regular machine shop?
Also, what tolerance should I give them? +/-0.001"? Below are my numbers for a Raby 9590 cam with 0.426" lift for exhaust and intake. Are these numbers typical? Cylinder.....Intake Lift....Intake Rod Length 1...............0.432................10.567" 2...............0.433................10.607 3...............0.431................10.640 (required 0.03 shim) 4...............0.424................10.578 Cylinder.....Exhaust Lift....Exhaust Rod Length 1...............0.410...............10.623" 2...............0.409...............10.618 3...............0.412...............10.663 (required 0.03 shim) 4...............0.410...............10.612 |
stugray |
Jan 23 2014, 10:09 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I believe I cut mine with a hacksaw ~1/16" long and then ground them down with a bench belt sander.
I was able to get them very accurate. I was also able to find a length that worked fine for all valves. I did not have to make custom lengths for each valve. The number I used is written down at home but was very close to what Jake reccommends starting with. I also shimmed my rockers up by a small amount (.049 if I recall correctly I have to look). But I have pretty big valve lift (.505 & .475 ish) We sanded the shims to match exactly between the 8 locations. |
Lo-Fi Version | Time is now: 9th June 2024 - 09:30 PM |
