| DamonsCarrera |
Nov 24 2013, 06:26 PM
Newbie ![]() Group: Members Posts: 36 Joined: 2-September 12 From: Chicago IL Member No.: 14,886 Region Association: Upper MidWest |
The brake pedal on my 914-6 is very spongy, even after repeated bleeding with a pressure bleeder. I isolated the problem to the brake-proportioning valve or pressure regulator. I cannot seem to get the brakes properly bled with this valve in the system.
I've read other posts by some here and it seems this valve is a source of some debate . Is there some trick to bleeding the brakes with it? Do I need to bleed the brakes the old-fashioned way, have someone push on the brake pedal? |
| stugray |
Jan 25 2014, 11:20 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Which model tilton did you get? Did it fit easily with no mods or is this a radical pedal modification? Pics?
DamonsCarrera Rear brake pressure regulator valve Nov 24 2013, 06:26 PM
toolguy No trick concerning the proportioning valve. . . a... Nov 24 2013, 06:40 PM
DamonsCarrera Thanks for your input toolguy. I guess I will try... Nov 24 2013, 07:17 PM
nine9three Everybody needs these: http://speedbleeder.com/ Nov 24 2013, 08:44 PM
toolguy Air seeping past the bleeder threads on the calipe... Nov 24 2013, 08:46 PM
914_teener :agree:
+1 Nov 24 2013, 08:47 PM
gothspeed
:agree:
+1
+2 .... :agree: Nov 24 2013, 09:37 PM
Mark Henry If you don't mind the super-fund clean-up mess... Nov 24 2013, 08:56 PM
barefoot
If you don't mind the super-fund clean-up mes... Jan 25 2014, 12:01 PM
ConeDodger Don't remove the valve. You will eventually co... Nov 24 2013, 09:05 PM
walterolin Speed bleeders (above). I did my '70 4 cyl la... Nov 24 2013, 09:29 PM
r_towle After you think you are done, drive it and slam th... Nov 24 2013, 09:47 PM
DamonsCarrera Thanks for all the advice guys.
Mark, besides b... Nov 25 2013, 05:56 AM
Eric_Shea There is no aftermarket valve.
It is a "pres... Nov 25 2013, 05:24 PM
DamonsCarrera I think there are other aftermarket valves availab... Nov 25 2013, 07:47 PM
Racer Chris There is nothing about the pressure regulator whic... Nov 25 2013, 11:32 PM
Racer Chris
There is nothing about the pressure regulator whi... Dec 22 2013, 10:31 PM
Eric_Shea
There's 100's of bias proportioning valv... Nov 27 2013, 04:24 PM
DamonsCarrera Sorry for the late response. Work has been a bear... Dec 21 2013, 03:51 PM
GeorgeRud I wonder if an additional bleeder at the highest p... Dec 21 2013, 05:41 PM
DamonsCarrera The highest point would probably be the at the top... Dec 21 2013, 08:51 PM
DamonsCarrera I've decided for now to replace the factory pr... Dec 22 2013, 01:13 PM
r_towle
The brake pedal on my 914-6 is very spongy, even ... Dec 22 2013, 04:24 PM
Eric_Shea Wrong move. All the Tilton can do is reduce fluid ... Dec 22 2013, 11:48 PM
SirAndy Wrong move. All the Tilton can do is reduce fluid ... Dec 23 2013, 03:15 AM
Racer Chris
Wrong move. All the Tilton can do is reduce fluid... Dec 23 2013, 08:30 AM
Jeff Hail
[quote name='Eric_Shea' post='1973906' date='Dec ... Dec 23 2013, 03:29 PM
Eric_Shea I disagree. ;) Dec 23 2013, 02:22 PM
Eric_Shea You boys have fun... I agree on the pressure aspec... Dec 23 2013, 04:27 PM
DamonsCarrera Don't know what the argument is about. It see... Dec 25 2013, 03:25 PM
DamonsCarrera Well, in case anybody is following this thread ...... Jan 24 2014, 09:39 PM
Bob L.
So next on the agenda, after making a permanent ... Jan 25 2014, 04:29 PM
914_teener I would think your next move is..... if you want t... Jan 24 2014, 10:23 PM
DamonsCarrera Yes, true. I set the valve according to the chart... Jan 25 2014, 10:10 AM
DamonsCarrera @barefoot
I think Mark was referring to cracki... Jan 25 2014, 12:23 PM
914_teener I have re-read your posts and I have a few questio... Jan 25 2014, 02:54 PM
DamonsCarrera @ 914 teener
The difference between a static valv... Jan 25 2014, 05:40 PM
914_teener Ok....so if it is static then the output will be l... Jan 25 2014, 06:05 PM
I'm not sure how you mean to use... Jan 25 2014, 08:03 PM
flypfi DamonsCarrera - I realize this is an old post, but... Nov 21 2016, 04:12 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:18 PM |
