tire choise, what do you use? |
effutuo101 |
Jan 16 2014, 06:52 PM
Advanced Member Group: Members Posts: 2,735 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California |
Ok, so, as I reach a point that i am looking at tires, i am debating on what to get.
I won't be driving the car in the cold, so, summer performance is the best choice. Also, Rain is not much of a factor where I live. I am looking for the best performing tire for street/autocross use. As I don't drive that much, getting a tire that will only survive 20k miles is quite all right. What do you use? feed back please. my tire size is 17, Front 240/40 17 rear 255 or 265/40 17 thank you in advance! |
effutuo101 |
Jan 24 2014, 05:35 PM
275 40R17's look gooood!
f1rocks |
Jan 27 2014, 10:07 AM
F1rocks Group: Members Posts: 23 Joined: 13-January 14 From: Brentwood, Tennessee Member No.: 16,884 Region Association: South East States |
FWIW,
888's were our spec tire for racing when Toyo was going to discontinue the RA1's. Miserable tire on light weight cars. The 944 spec weighs about 2290 wet, 888's were significantly slower than the RA1's. They wear like iron. I couldn't kill the one set I was stuck with and eventually just through them away before they corded or heat cycled. The 888's are supposedly better for heavier cars but you will not be able to get enough heat into them with a 914. If you can get a proper size, the RA1 or RR (which is the bomb) would be much nicer. |
Lo-Fi Version | Time is now: 10th June 2024 - 01:22 AM |
