| '73-914kid |
Jan 25 2014, 01:26 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
Today I planned on doing the first oil change in my car after doing the 6. The front cooler was always leaking, so I had kept adding enough oil that kept it relatively clean... the leak was fixed, and I had driven it for another 1,000 or so miles, no big deal, oil is dirty, time to change it.
Get a Mahle Filter yesterday, figure I'll go and get a case of Brad Penn like I always do from VW Paradise here in San Marcos. Apperantly, they aren't selling it anymore because they have to buy it in 80 case lots from Brad Penn. Fair enough, that's not very economical for a small shop. So I've been driving around all damn morning to 4 or 5 different auto parts stores to try and find enough Valvoline VR1 to fill up this engine... Not happening. I've ended up with 8 quarts of the stuff. Need 6 more. (IMG:style_emoticons/default/headbang.gif) So here I stand, 6 quarts of oil short, trying to do an oil change because with the local Brad Penn source nonexistant, I'm assuming everyone else who ran BP is buying up all the VR1 now. (IMG:style_emoticons/default/hissyfit.gif) Anyways, rant over... and for those of you local to me, be warned, VW Paradise no longer sells the good stuff, so don't drive all the way here only to find out they don't have any. |
| Jake Raby |
Jan 27 2014, 07:08 AM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Diesel engines actually have different wear mechanisms than gasoline engines. For example, soot control is much much more important and diesel engine than a gasoline engine. In a diesel engine, soot particles can create more wear than anything else. Accordingly the best way to reduce where in a diesel engine is through such control, which means more dispersant additives.
High-speed gasoline engines do not suffer from soot related wear. The point here is that just because an oil is better for wear in a diesel engine, does not mean it is better for wear in high-speed gasoline engine applications. Different engines. Different mode of wear, and different lubricant chemistry. Fact is it took Diesel oils longer to be impacted by lubricant changes than gasoline oils, but once it hit them they became even more compromised. My Duramax Diesel has 180K miles on it and makes 505 RWHP on my chassis dyno (spinning tires) and is filled with Joe Gibbs DP40 Turbo Diesel oil. That said, I don't sell a single product outside of a complete engine anymore, that includes oil. Thank goodness! It really doesn't matter to me which oil is used and I would not have even posted if this thread hadn't been sent to me by the owner of one of my engines that saw it. He then wanted to run Rotella, even though it specifically states in my 80 page engine manual NOT to use this oil. Hell, Maybe we should all be using Mil-L-23699 Turbine Engine oil? If its so cool to use a lubricant thats designed for a completely different application, might as well go straight to Jet engine oil! |
| r_towle |
Jan 27 2014, 11:55 AM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
It really doesn't matter to me which oil is used and I would not have even posted if this thread hadn't been sent to me by the owner of one of my engines that saw it. He then wanted to run Rotella, even though it specifically states in my 80 page engine manual NOT to use this oil. I totally agree that you should not let your customers of your engines do anything that would void your guidelines...no question about it. The overall lack of available oil for the rest of the pushrod community, not just aircooled, has sparked quite a bit of debate, and more than a few real world tests on both dyno's and lab results. These facts may support the decision, may not. If I was to buy a custom motor from any engine builder, I would never question what they tell me with regards to upkeep and maintenance....that is what I would have paid for. Certainly the customer that has to rely upon the builder and nothing else, if they are smart. Rich |
'73-914kid Oil Availability Rant.... Jan 25 2014, 01:26 PM
somd914 Just another case of a company loosing sight of it... Jan 25 2014, 01:43 PM
SLITS Brad Penn
Kendal GT with Liquid Titanium (my pref... Jan 25 2014, 02:38 PM
396
Brad Penn
Kendal GT with Liquid Titanium (my pre... Jan 26 2014, 11:30 AM
914itis Same issue here in Ny I haven't been able to f... Jan 25 2014, 02:42 PM
JimN73 Try Amazon. Free shipping on orders on case lots.... Jan 25 2014, 02:43 PM
Try Amazon. Free shipping on orders on case lots... Jan 25 2014, 03:49 PM
'73-914kid
[quote name='JimN73' post='1988317' date='Jan 25 ... Jan 26 2014, 11:22 AM
[quote name='JimN73' post='1988317' date='Jan 25... Jan 26 2014, 11:56 AM
pilothyer Don't forget Joe Gibbs DT50
DT50LINK) Jan 25 2014, 02:45 PM
The Cabinetmaker Try your local hotrod, v8, speed shop for brad pen... Jan 25 2014, 02:58 PM
carr914 I buy Oil from Amazon by the Case Jan 25 2014, 03:10 PM
saigon71 After some research, I started running this synthe... Jan 25 2014, 03:14 PM
ndfrigi About Brad Penn, what can you recommend for a 1.8L... Jan 25 2014, 03:21 PM
Jake Raby Brad Penn has never been easy to work with for a d... Jan 26 2014, 09:43 AM
Jake Raby Kendall is just a generic oil today and has been f... Jan 26 2014, 01:20 PM
PanelBilly My niece is an engineer who works for Mobile. She ... Jan 26 2014, 01:39 PM
Jake Raby
My niece is an engineer who works for Mobile. She... Jan 26 2014, 01:56 PM
MMW I agree to just buy a case of Brad Penn & put ... Jan 26 2014, 02:29 PM
hot_shoe914 http://theoilwarehouse.com/?mainURL=/store...rmanc... Jan 26 2014, 03:00 PM
r_towle Rotella diesel oil
Shell product, easy to find
Fil... Jan 26 2014, 06:32 PM
OU8AVW
Rotella diesel oil
Fi... Jan 26 2014, 08:25 PM
r_towle
Rotella diesel oil
F... Jan 26 2014, 08:44 PM
Jake Raby
Rotella diesel oil
Fi... Jan 26 2014, 08:55 PM
r_towle Rotella triple protection.
Used in both my 911 an... Jan 26 2014, 08:54 PM
r_towle Shell is marketing their new CJ-4/SM oil as ... Jan 26 2014, 09:02 PM
Jake Raby Key Word:
Marketing
Believe nothing of what you h... Jan 26 2014, 09:37 PM
r_towle
Key Word:
marketing
positively promoting your pr... Jan 26 2014, 10:04 PM
Woody Oohh an oil thread. Yay! :poke: Jan 26 2014, 09:55 PM
'73-914kid Wow, how did this turn into an oil quality debate.... Jan 27 2014, 01:18 PM
vw505 Jake its MIL-PRF-23699 now it changed back in 08. Jan 27 2014, 01:30 PM
brant diesel oils aren't the solution they used to b... Jan 27 2014, 01:43 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th May 2026 - 10:55 PM |
