> How to you bench test electrical things?, How to you bench test electrical things?
lonewolfe
post Jan 30 2014, 02:44 AM
I'm curious what you all do to bench test electrical items? I'm just not very knowledgeable about electrical things. I have some gauges, fog lights and other items I'd like to be able to bench test but don't know the best way to power them. Our cars of course run on 12v systems. Is there some sort of device to use that allows one to adjust voltage?
I know this sounds like a dumb question but I'm sure there must be a safe way to test electrical devices for our cars.
Anyone?
type47
post Jan 30 2014, 06:04 AM
Viermeister
use an old battery that you kept instead of turning in as a core and some wires with alligator clips. Charge the battery with a $20 Black and Decker trickle charger from local hardware store. Easy access to +12VDC and ground.....
lonewolfe   How to you bench test electrical things?   Jan 30 2014, 02:44 AM
falcor75   Something like this should work I guess. http://w...   Jan 30 2014, 03:29 AM
cary   Something like this should work I guess. http://...   Jan 30 2014, 09:43 AM
type47   use an old battery that you kept instead of turnin...   Jan 30 2014, 06:04 AM
dlestep   First, you need a bench. Secondly, you need the ri...   Jan 30 2014, 09:03 AM
76-914   No such thing as a stupid question. Do you have a ...   Jan 30 2014, 09:15 AM
914GT   I use a cheap Harbor Freight power pack, under ...   Jan 30 2014, 12:58 PM
messix   Invest in some time at the university of Google an...   Jan 30 2014, 02:03 PM
r_towle   All the devices on the car will require 12 Volts D...   Jan 30 2014, 02:20 PM
lonewolfe   Thanks for all the suggestions! And you are ri...   Jan 30 2014, 02:52 PM
r_towle   Keep asking questions. Its how you can learn, and ...   Jan 30 2014, 03:28 PM
Tom   Giving someone advise on how to test electrical th...   Jan 30 2014, 03:37 PM
Spoke   Giving someone advise on how to test electrical t...   Jan 30 2014, 04:25 PM
lonewolfe   Admittedly, I need to study up on all things elect...   Jan 30 2014, 04:30 PM
messix   You can ruin some elctrical circuits if you connec...   Jan 30 2014, 05:31 PM
lonewolfe   You can ruin some elctrical circuits if you conne...   Jan 30 2014, 06:19 PM
r_towle   Don't let fear scare you away from learning. O...   Jan 30 2014, 07:16 PM
somd914   One bad thing about using an old battery is the am...   Jan 30 2014, 07:51 PM
lonewolfe   One bad thing about using an old battery is the a...   Jan 30 2014, 08:08 PM
r_towle   For automotive testing 12 vdc, 20 amps Should be m...   Jan 30 2014, 08:58 PM
messix   12V regulated power supply's are not cheap, no...   Jan 30 2014, 09:25 PM
dlestep   12V regulated power supply's are not cheap, n...   Jan 31 2014, 08:03 AM
CptTripps   I spent $ on a 30A regulated power supply abo...   Jan 31 2014, 02:25 AM
somd914   No need to spend big bucks on pro-level supplies f...   Jan 31 2014, 05:06 AM
Tom   Dave, That W between Y and B should be a G. For...   Feb 6 2014, 12:38 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 06:41 PM
