> Plumbing Question #2
Porsche Rescue
post Apr 29 2003, 08:35 AM
Saving and Enjoying Old Porsches
Now that I have a handle on Weber fuel plumbing, I am moving on to oil vapor hoses. The engine I am installing is my first with carbs. Can someone tell me what the two small open pipes beside the intake manifolds are for? I assume they are on stock FI engine and I just never noticed them.
I believe I need some sort of vapor cannister (have seen one made by K&N). Do I connect it to the plastic nipple at the oil filler and then to the two nipples at the manifolds? Is this a crankcase vent system? Is there a PCV valve needed? By now you can tell that I'm not real sure I know what I'm doing!
MarkV
post Apr 29 2003, 03:10 PM
Fear the Jack Stands
So on my carbed 2.0 4cyl car there are vacuum ports on the tops of the air cleaners. The pass side air cleaner is connected to the factory PCV valve. The drivers side air cleaner is connected to the factory tee that connects to both heads. Seems like this would give you a positive flow of fresh air through the engine. Is there an advantage to running the air box instead? (IMG:style_emoticons/default/confused24.gif)
- Lo-Fi Version Time is now: 17th July 2025 - 02:56 AM
