OU8AVW |
Yacht Rigger ![]() ![]() ![]() Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region ![]() |
Next step for me is setting up my valve train geometry. I searched the web and the World and now I have enough information to know that I need more information. I see a few references to an article Jake had on his now extinct forums. The Facebook page is pretty vast. Can someone point me to this article? I think that's my first step toward comming up with more intelegent questions.
FYI: I'm building a 2056 based on a late case. I have Jake's 9550 cam installed I have swivel feet adjusters mounted on 1.7 rockers with solid spacers I am using SS valves and chromoloy push rods I installed 8x10 rocker studs I have used .065" of shim on the cylinders with no head gasket Thanks! (IMG:style_emoticons/default/piratenanner.gif) |
OU8AVW |
Thanks guys.
If you don't like something in the write up, if you don't like Jake Raby, please post your comments somewhere else. This is a valve train thread..... Anyone have an adjustable pushrod I can use? I can manage everything else. |
Bulldog9 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region ![]() |
Thanks guys. If you don't like something in the write up, if you don't like Jake Raby, please post your comments somewhere else. This is a valve train thread..... Anyone have an adjustable pushrod I can use? I can manage everything else. I shot you a PM yesterday, give me a call will get it to you. In fact, will bring it to you, could really use the opportuynity to watch/learn as you do this. This is the only area I have aknot in my stomach over..... As we discussed in the past I think our engine and valvetrain layouts are exactly the same, down to the spacer of which mine is a .060. Give me a call! |
OU8AVW |
Thanks guys. If you don't like something in the write up, if you don't like Jake Raby, please post your comments somewhere else. This is a valve train thread..... Anyone have an adjustable pushrod I can use? I can manage everything else. I shot you a PM yesterday, give me a call will get it to you. In fact, will bring it to you, could really use the opportuynity to watch/learn as you do this. This is the only area I have aknot in my stomach over..... As we discussed in the past I think our engine and valvetrain layouts are exactly the same, down to the spacer of which mine is a .060. Give me a call! Sounds good. I'll collect the required tooling and get back to you, maybe next week. Lots of pictures to come. |
Lo-Fi Version | Time is now: 13th June 2024 - 10:04 AM |
