| Cfletch |
Jan 31 2014, 10:43 PM
Member ![]() ![]() Group: Members Posts: 231 Joined: 30-January 14 From: Santa Barbara Member No.: 16,941 Region Association: Southern California |
So I am new to the forums and also new to owning a 914. This monday I bought a 1970 914 and have had fun driving it around! But i have noticed a problem with the idling. After getting off the freeway and then putting it into neutral to wait at a light i noticed the rpms going from about 900-1000 (normal idle rpm) and slowly climb up to about 1700 or so and the only way I am able to make it normal for a few seconds is to tap the gas. Another thing i have noticed is it will occasionally bounce around from 1000 rpm up to 1800 rpm in a few seconds on its own without any input from the throttle. Does anybody know what my problem is and how I can come about fixing it?
Thanks, and my name is Colin |
| luskesq |
Jan 31 2014, 11:29 PM
Member ![]() ![]() Group: Members Posts: 276 Joined: 24-October 10 From: Fresno, CA Member No.: 12,303 Region Association: Central California |
Although a vacuum leak is always a possibility, I had the same issue and it was my timing. It is easy enough to check that but do so after first setting your points.
Keith |
Cfletch Idle Problems Jan 31 2014, 10:43 PM
r_towle First off, welcome to the world of 914 ownership.
... Jan 31 2014, 10:59 PM
Cfletch
First off, welcome to the world of 914 ownership.... Jan 31 2014, 11:14 PM
boxsterfan Sounds like a vacuum leak. Check all you vacuum ho... Jan 31 2014, 11:19 PM
Cfletch I think tomorrow ill check around for a vacuum lea... Jan 31 2014, 11:37 PM
r_towle Vacuum leak is first.
Clean the advance plates and... Feb 1 2014, 10:31 AM
The Cabinetmaker Also, check the throttle cable for being too tight... Feb 1 2014, 10:58 AM
Cfletch Alright so after checking out the distributor I ha... Feb 1 2014, 04:07 PM
Cfletch so after all my attempts today was a failure :/ i ... Feb 2 2014, 10:15 PM
boxsterfan You can try running without decel valve. Just bloc... Feb 2 2014, 11:18 PM
Dave_Darling The air cleaner is at close to ambient air pressur... Feb 3 2014, 10:15 AM
r_towle The car needs one single vacuum hose connected to ... Feb 3 2014, 10:40 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:02 PM |
