front air dam, correct ride height? |
Trekkor |
Aug 3 2004, 12:00 AM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
I'm setting up a custom rubber flex dam off an LE F/G dam.
I want the clearance to be the ABSOLUTE minimum. How much room should I allow? Can't limbo under my dam. (IMG:style_emoticons/default/jester.gif) Flexy T |
maf914 |
Aug 3 2004, 11:51 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
QUOTE(markd@mac.com @ Aug 3 2004, 06:30 AM) There's a reason Porsche added the two "air flaps" on the front lip of the engine bay in 1973. Those two guys stir up the air to create turbulence and get more air up around the engine and cool it. There are a lot of opinions about the two flaps Porsche added. I don't think they are there to create turbulence, but are there to direct the airlow from the floor pan down and away from the areas under the cylinders and heads, creating a low pressure area that lets the pressurized cooling air from the cooling fan and shroud exit from the cylinders and heads more easily. The fact that they didn't use a single flap across the engine bay makes me wonder if they wanted some airflow across the finned bottom of the sump. I don't know how much cooling occurs at the sump. It seems it would be relatively small. I've also wondered about the effects front spoilers have on 914 cooling. I still think someone needs to get a 914 into a full scale rolling road wind tunnel and test out all of our theories! (IMG:style_emoticons/default/laugh.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 07:49 AM |
