Valve Train Time, Raby article now posted with permission |
OU8AVW |
Jan 30 2014, 06:31 PM
Yacht Rigger Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region |
Next step for me is setting up my valve train geometry. I searched the web and the World and now I have enough information to know that I need more information. I see a few references to an article Jake had on his now extinct forums. The Facebook page is pretty vast. Can someone point me to this article? I think that's my first step toward comming up with more intelegent questions.
FYI: I'm building a 2056 based on a late case. I have Jake's 9550 cam installed I have swivel feet adjusters mounted on 1.7 rockers with solid spacers I am using SS valves and chromoloy push rods I installed 8x10 rocker studs I have used .065" of shim on the cylinders with no head gasket Thanks! (IMG:style_emoticons/default/piratenanner.gif) |
OU8AVW |
Jan 31 2014, 06:26 AM
Thanks guys.
If you don't like something in the write up, if you don't like Jake Raby, please post your comments somewhere else. This is a valve train thread..... Anyone have an adjustable pushrod I can use? I can manage everything else. |
worn |
Jan 31 2014, 08:20 AM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Thanks guys. If you don't like something in the write up, if you don't like Jake Raby, please post your comments somewhere else. This is a valve train thread..... Anyone have an adjustable pushrod I can use? I can manage everything else. If you are replacing them it is easy to make one out of the old one. The aluminum is ver thick, easily tapped. I use 1/4 by 20 because it is very common around my shop. The nuts are lock nuts. |
OU8AVW |
Feb 1 2014, 08:18 PM
Thanks guys. If you don't like something in the write up, if you don't like Jake Raby, please post your comments somewhere else. This is a valve train thread..... Anyone have an adjustable pushrod I can use? I can manage everything else. If you are replacing them it is easy to make one out of the old one. The aluminum is ver thick, easily tapped. I use 1/4 by 20 because it is very common around my shop. The nuts are lock nuts. I can handle this, no problem. |
Lo-Fi Version | Time is now: 1st June 2024 - 02:06 AM |
