> Gear shift adjustment, left and right
Kent
post Dec 20 2008, 11:39 PM
Any helpfull hint on how th get the left /right adjustmet correct on the interior gear shift adjustment? I hve figured out forward and back.
ChrisFoley
post Dec 21 2008, 12:06 AM
I am Tangerine Racing
With the trans in neutral, attach a bungee from the shift lever to the passenger side door handle while the adjustment bolt is loose. Rotate the splined shaft to the right as far as it will go, then tighten the bolt.
jim_hoyland
post Feb 1 2014, 09:42 PM
Get that VIN ?
QUOTE(Racer Chris @ Dec 20 2008, 10:06 PM) *
Would this work for a Rennshifter as we'll ?
ChrisFoley
post Feb 2 2014, 08:33 AM
QUOTE(jim_hoyland @ Feb 1 2014, 10:42 PM) *
In concept, yes.
However, the centering springs probably make it difficult.
Kent   Gear shift adjustment   Dec 20 2008, 11:39 PM
Racer Chris   With the trans in neutral, attach a bungee from th...   Dec 21 2008, 12:06 AM
jim_hoyland   With the trans in neutral, attach a bungee from t...   Feb 1 2014, 09:42 PM
Racer Chris   With the trans in neutral, attach a bungee from ...   Feb 2 2014, 08:33 AM
Bruce Hinds   With the trans in neutral, attach a bungee from t...   Aug 19 2025, 03:46 PM
Joe Ricard   Damn I have been screwing around with "one sp...   Dec 24 2008, 09:02 PM
cpavlenko   :shock1: :shock1: :shock1: that is so simple, I...   Mar 11 2014, 10:06 PM
Red72   A bit of a ressurection here, but I'm having s...   May 18 2015, 05:57 PM
tomrev   A bit of a ressurection here, but I'm having ...   May 18 2015, 06:44 PM
Red72   A bit of a ressurection here, but I'm having...   May 21 2015, 12:01 PM
stugray   Another trick I have learned (even if using Racer ...   May 21 2015, 12:21 PM
Red72   So I'm now back to a point where I have first ...   May 24 2015, 04:58 PM
Dr Evil   Nope. The 4-5, 2-3 throws on a properly adjusted b...   May 25 2015, 09:05 PM
Hine62   Where is the adjustment screw? I think R & 1st...   Jun 8 2015, 01:11 PM
stugray   Where is the adjustment screw? I think R & 1s...   Jun 8 2015, 05:06 PM
rgalla9146   Mark both pieces with a fine tip magic marker put...   Jun 8 2015, 06:37 PM
db9146   So mine is a tailshifter and I just finished repla...   Jun 8 2015, 08:42 PM
Dave_Darling   Sounds like you may need to adjust the lever over ...   Jun 8 2015, 08:58 PM
RobW   I use the put it wrong method, and then estimating...   Jun 9 2015, 07:43 AM
Racer Chris   I use the put it wrong method, and then estimatin...   Jun 9 2015, 08:48 AM
Dr Evil   Put in 2nd. Disconnect shifter at rod (side shift)...   Jun 9 2015, 07:42 PM
Bruce Hinds   Put in 2nd. Disconnect shifter at rod (side shift...   Aug 19 2025, 08:48 PM
jdahl   Need some help here, I've tried Dr. Evil and R...   Dec 3 2016, 10:47 AM
Racer Chris   ... and rotated spline by spline. ... The splin...   Dec 3 2016, 03:01 PM
SKL1   Get Chris' new front adjuster... just a satis...   Dec 3 2016, 12:30 PM
Keith914   Check that nothing is preventing full left to righ...   Dec 3 2016, 02:03 PM
Dave_Darling   Check that nothing is preventing full left to rig...   Aug 19 2025, 07:07 PM
porschetub   I continue to struggle with mine and think I'a...   Dec 3 2016, 02:54 PM
Jack Standz   There is an access hole towards the rear of the ca...   Aug 19 2025, 06:55 PM
Bruce Hinds   There is an access hole towards the rear of the c...   Aug 19 2025, 08:43 PM
- Lo-Fi Version Time is now: 11th November 2026 - 06:35 PM
