fuel delivery differences (HP) |
RonnieJ |
Feb 2 2014, 11:30 AM
RonnieJ Group: Members Posts: 230 Joined: 16-June 03 From: Sterling Heights, Michigan Member No.: 829 Region Association: Upper MidWest |
What will a stock 1.7 produce in H.P.with the following.
Progressive 32/36 Weber 40's D-Jet F.I. |
brant |
Feb 2 2014, 11:41 AM
914 Wizard Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
not answering your question exactly
but its more about throttle response than actual HP numbers for example a giant set of 48IDA carbs might actually flow the most air and on a dyno at 7K might show the most hp... but they won't be driveable below 6K the progressive carb also isn't very smooth when the fuel falls out of suspension in the intake runners causing rich and lean moments.. so its more than just HP unless you are racing and have a very narrow range of 1000rpm or less that you are trying to get it to function within. you can make your question more specific what are you trying to do? are you asking which induction to use on a stock 1.7 with stock everything else including heads, compression, cams, and exhaust? then DJet is the answer brant |
Lo-Fi Version | Time is now: 10th June 2024 - 03:13 PM |
