| Cfletch |
Jan 31 2014, 10:43 PM
Member ![]() ![]() Group: Members Posts: 231 Joined: 30-January 14 From: Santa Barbara Member No.: 16,941 Region Association: Southern California |
So I am new to the forums and also new to owning a 914. This monday I bought a 1970 914 and have had fun driving it around! But i have noticed a problem with the idling. After getting off the freeway and then putting it into neutral to wait at a light i noticed the rpms going from about 900-1000 (normal idle rpm) and slowly climb up to about 1700 or so and the only way I am able to make it normal for a few seconds is to tap the gas. Another thing i have noticed is it will occasionally bounce around from 1000 rpm up to 1800 rpm in a few seconds on its own without any input from the throttle. Does anybody know what my problem is and how I can come about fixing it?
Thanks, and my name is Colin |
| r_towle |
Feb 3 2014, 10:40 AM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
The car needs one single vacuum hose connected to the plenum to run.
The MPS. I remove all the other hoses and plug the plenum at those locations. Then see if you fixed it... If so, start adding back ONE line at a time to see if the line is good, or the device is good etc.... Basic troubleshooting. They sell rubber caps cheap at the local hardware store. Unless you have an aftermarket distributor, there are no NEW distributors out there....maybe clean ones, maybe painted one, but no new ones. Rich |
Cfletch Idle Problems Jan 31 2014, 10:43 PM
r_towle First off, welcome to the world of 914 ownership.
... Jan 31 2014, 10:59 PM
Cfletch
First off, welcome to the world of 914 ownership.... Jan 31 2014, 11:14 PM
boxsterfan Sounds like a vacuum leak. Check all you vacuum ho... Jan 31 2014, 11:19 PM
luskesq Although a vacuum leak is always a possibility, I ... Jan 31 2014, 11:29 PM
Cfletch I think tomorrow ill check around for a vacuum lea... Jan 31 2014, 11:37 PM
r_towle Vacuum leak is first.
Clean the advance plates and... Feb 1 2014, 10:31 AM
The Cabinetmaker Also, check the throttle cable for being too tight... Feb 1 2014, 10:58 AM
Cfletch Alright so after checking out the distributor I ha... Feb 1 2014, 04:07 PM
Cfletch so after all my attempts today was a failure :/ i ... Feb 2 2014, 10:15 PM
boxsterfan You can try running without decel valve. Just bloc... Feb 2 2014, 11:18 PM
Dave_Darling The air cleaner is at close to ambient air pressur... Feb 3 2014, 10:15 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:03 PM |
