Vysoc |
Vysoc ![]() ![]() ![]() Group: Members Posts: 586 Joined: 27-August 09 From: Young Harris, Georgia Member No.: 10,737 Region Association: South East States ![]() |
Hello,
Just enjoying the PreSuper Bowl when I noticed my brake lights were not lighting up? The rear running lights light up when the lights come on, the turn signals work, the hazards work, the fogs work, The back-up light works. I checked the fuses all good, I checked the bulbs all good. I looked at the connections at the rear lights and good on both sides. I checked under the pedals and the wires are connected to the brake sensor or sending unit. Could the sending unit at the brake pedal maybe have gone bad or is there a relay or something I am missing? Thanks, Vysoc (IMG:style_emoticons/default/flag.gif) |
dangrouche |
dangrouche ![]() ![]() ![]() Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None ![]() |
instead of that dremel, I make my own sanding "pole".
take a brand new #2 pencil with an unused eraser, a sheet of 400 grit emery paper, a hole puncher, and a glue stick. Glue a dot of sandpaper onto the eraser and use this sanding "pole" to clean the socket contacts, follow up with compessed air to blow out the grindings |
Lo-Fi Version | Time is now: 17th June 2024 - 11:21 AM |
