> ISO Trailing arm bushing ream advice
HalfMoon
post Feb 7 2014, 04:30 PM
Hi all,
I'm doing my trailing arms bushings today (poly) and knowing they have to be reamed for the shaft so I grabbed a brake/cylinder honer I had handy and started boring the bushing (like what I'd seen in threads here at World.)
Unfortunately I'll grow old a die before this method gets me anywhere. Simply put, it's not cutting it (or hardly).
I saw in a thread that Eric with PMB now uses a small 3X1 barrel sander to get this work done (like this one http://www.mcmaster.com/#rubber-drums/=qlel82) and so I guess I'll go ahead and order one along with a bunch of sanding bands...but even then, I've heard the task can be a rather long one.
Anyone have experience with this job and have a tool recommendation to cut this material using garage type tools (drill)?
HalfMoon
post Feb 12 2014, 10:03 PM
80 grit, 1"X1", flapper wheel from NAPA did the job quite well. And believe it or not, an 80 grit on my ginder faced em nicely too.
I installed the 6mm zerks per Eric's vid as well, so all good again :-)
- Lo-Fi Version Time is now: 2nd April 2026 - 05:25 PM
