Sway Bar Confusion, Anyone seen this before? |
MAD914 |
Feb 12 2014, 05:38 PM
Newbie Group: Members Posts: 23 Joined: 3-August 11 From: La Verne, CA Member No.: 13,390 Region Association: Southern California |
This is my 74' 2.0. I took the gas tank out in preparation for installing an anti-sway bar (among other things), and this is what I found:
The passenger side is fine, all ready for a mounting plate. But then: On the driver's side, there is a stock plate spot-welded in, but neither the bolt holes or the hole for the bar are punched through. What the hell? Now I guess I have to drill out the spot welds, take the "stock" plate off, and install a proper reinforcement on both sides? I also thought of trying to thread a bolt into the existing nuts and maybe snap them off by hitting it with a hammer. Then I could leave the existing plate in place, and just drill through it to mount my new plate on the inner (gas tank) side of the sheet metal - but what about the nut that's down below the existing crosspiece? Oddly enough, the A-arms also have the stock U-tabs on them, even though the car didn't come with a front bar. I'm thinking maybe the schnitzel truck pulled into the Karmann factory early, and Gunter and Helmut didn't want to be last in line, so they just left the assembly line with the car halfway prepared for a sway bar. Anyone seen anything like this, or have any advice on the best way to proceed? Thanks, |
MAD914 |
Feb 14 2014, 02:48 PM
I had no idea that a sardonic sense of humor was so closely tied to 914 ownership.
I've looked carefully at the area, and can't find any seams, cuts, or welds that would make me think there was a large graft from another car. The seam sealer on the driver's side is just out of the frame of the photo I took, and it looks stock as well. This is the fenderwell with the [matching] VIN stamped on it, so again, I think it's all stock. The holes for the bolts and the bar are very cleanly "punched", not drilled, as far as I can tell. I've owned the car since 1983 (the whole car has always been black), so PO damage is possibly less likely. I guess my next move is to clean off the wheel well side, take a look, and possibly start drilling out spot welds to take this thing off. In keeping with "balljoint's" comment, I've begun referring to this thing as the "schnitzel plate" (as opposed to a "taco plate"). Any other ideas? |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:40 AM |
