Sway Bar Confusion, Anyone seen this before? |
MAD914 |
Feb 12 2014, 05:38 PM
Newbie Group: Members Posts: 23 Joined: 3-August 11 From: La Verne, CA Member No.: 13,390 Region Association: Southern California |
This is my 74' 2.0. I took the gas tank out in preparation for installing an anti-sway bar (among other things), and this is what I found:
The passenger side is fine, all ready for a mounting plate. But then: On the driver's side, there is a stock plate spot-welded in, but neither the bolt holes or the hole for the bar are punched through. What the hell? Now I guess I have to drill out the spot welds, take the "stock" plate off, and install a proper reinforcement on both sides? I also thought of trying to thread a bolt into the existing nuts and maybe snap them off by hitting it with a hammer. Then I could leave the existing plate in place, and just drill through it to mount my new plate on the inner (gas tank) side of the sheet metal - but what about the nut that's down below the existing crosspiece? Oddly enough, the A-arms also have the stock U-tabs on them, even though the car didn't come with a front bar. I'm thinking maybe the schnitzel truck pulled into the Karmann factory early, and Gunter and Helmut didn't want to be last in line, so they just left the assembly line with the car halfway prepared for a sway bar. Anyone seen anything like this, or have any advice on the best way to proceed? Thanks, |
ChrisFoley |
Feb 15 2014, 08:57 AM
I am Tangerine Racing Group: Members Posts: 7,935 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Ed and I thought of a possible scenario which may explain this, depending on how the factory assemblyline was organized.
Helmut inadverdently set a fenderwell with prestamped holes in the assembly fixture during a run of non sway-bar equipped chassis'. The simplest solution for Gunter, working at the next station, was to cover it up with an unfinished mounting plate. There are many non sway-bar cars which came with the u-tabs on the a-arms. For a narrow body street car I would use it if I was able to drill out the bolt holes without destroying the threads. I would add a perimeter weld at the edge of the plate. |
r_towle |
Feb 15 2014, 02:17 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Ed and I thought of a possible scenario which may explain this, depending on how the factory assemblyline was organized. Helmut inadverdently set a fenderwell with prestamped holes in the assembly fixture during a run of non sway-bar equipped chassis'. The simplest solution for Gunter, working at the next station, was to cover it up with an unfinished mounting plate. To elaborate. Helmet had a rack of inner fenders that became empty right BEFORE lunch. Helmet and Gunter went to lunch with Hans. when walking back from lunch, with a slight buzz going, Helmet asked Hans to refill the rack of inner fenders! no one cared enough to ask which type of part was needed because it was AFTER lunch ( and two liters of beer) And work went forward as it normally does....no problem. Legally allowed to have not one, but TWO of these at lunch... It was in the workers contract at Siemens when I worked and lived there. I just went and looked it up. 33.4 ounces to a liter. So two liters is almost a six pack of beer when using cans. In under one hour.... Attached image(s) |
Lo-Fi Version | Time is now: 10th June 2024 - 12:52 PM |
