Triangle window seal installPic of late directions for both, How to - tools needed - other items |
Mikey914 |
Feb 17 2014, 12:27 AM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
First off I want to explain some of the photos. Pictures from my website have been showing up on other websites (9xauto), and I don't mind sharing info just not having what I've done show up on other commercial websites. I'm putting together an instructions for those that need it that by from my website, so it will be available on the site too.
Tool list - #2 Phillips screwdriver 10mm socket 13mm socket 6" extender for ratchet ratchet wrench 3/8? 13mm box wrench #4 standard screwdriver Wooden block and hammer Optional items to look at "while you are there" The Outer door fuzzy is difficult to access, you will be able to swap these out during this process. I do make the aluminum strips for early and late doors as well as the rollers for both Door handle isolators - If you need to swap out the seals on the door handles, this process will allow you to have more access. The door cam can be changed out at the same time. Locks can be rekeyed if needed and the door lock bushings replaced. Window rollers, both the early and late have rollers that are replaceable. The late doors have fuzzy strips that run vertical in the front and rear window guides, this is a good time to replace these too. The early door has rollers in the front track, the rear track has a plastic guide that runs up and down in the back track. The door stay is easily reached with the door panel removed. You can replace the rollers, springs, and the strap easily. The unit has a pin that holds it to the body, and 2 -10mm bolts hold the unit in. The fuzzy on the inside of the window can be replaced easily with the door panel off. Lastly the door end caps can be replaced at this time also. First off remove the door pockets, and plastic door handle cups. This will allow the door panel to be removed. Attached thumbnail(s) |
Mikey914 |
Feb 17 2014, 01:18 AM
To remove the vertical bar you will need to remove the aluminum track that houses the outer door fuzzy. There are 3 screws with access holes to reach them. I provide stainless screws to replace these with my outer fuzzy set. They are a #6. You may need to drill out the old ones if they are rusted in. Go slowly you may be able to get all out without incident.
Aluminum track removed below Attached thumbnail(s) |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:57 PM |
